strength of kick stand ?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 11-15-2013, 01:29 PM Thread Starter
Are the kick stands strong enough for boarding? Is this safe enough?
G.Aums is offline
post #2 of 19 Old 11-15-2013, 04:09 PM
Tydive's Avatar
I regularly stand on the pegs to get on or off the bike, while it is on the side stand. I weigh 165 + gear.
Edit: for safety I always hold the front brake while mounting or dismounting the bike.
[URL="https://www.stromtrooper.com/ride-reports-route-sheets/211578-california-idaho-lolo-motorway-magruder.html"]California to Idaho Adventure style[/URL]
[URL=http://bayarearidersforum.com/forums/showthread.php?t=478959]Taking America by Strom 2015[/URL]
Timing is everything.
Tydive is offline
post #3 of 19 Old 11-15-2013, 04:11 PM
I have a friend that did this and his kick stand broke after couple years. He took it to a welding shop and they reinforced it, its probably the strongest kick stand in the world. Cost him twenty bucks.
ronhawk62 is offline
post #4 of 19 Old 11-15-2013, 04:16 PM
tmcgee's Avatar
I don't use the side stand for getting on the bike, but always step on the peg when using the center stand.
tmcgee is offline
post #5 of 19 Old 11-15-2013, 07:30 PM
I do it everyday....215# plus gear. No probs
'12 DL650 ADV [I]"Maddie"[/I]
'03 DRZ400e (Plated)[I]"Big Bird"[/I]
'00 Triumph Sprint ST 955i [I]"Jolene"[/I]
Dan-tastic is offline
post #6 of 19 Old 11-15-2013, 07:35 PM
Same here. Never had a problem.
Redleg is offline
post #7 of 19 Old 11-15-2013, 08:01 PM
Sconde's Avatar
To get the back wheel off the ground to do chain maintenance I usually apply the front brake and then lift the back of the bike up so it rocks up onto the kickstand and the front tire. I then push a block of wood under the bottom of the rear suspension and then lower it back down. So I guess the kickstand can withstand at least the weight of the bike...
'12 650 ADV in White: Oxford heated grips, 12v socket x2, BarkBuster Storms, Pivot Pegz, OEM Aluminum cases and top box, OEM crashbars,
Sconde is offline
post #8 of 19 Old 11-15-2013, 09:08 PM
Be careful that the kickstand is fully forward if not when you put pressure on the peg and swing your leg over it will collapse and down you go. Don't ask me how I know.
Maddog251f is offline
post #9 of 19 Old 11-15-2013, 09:19 PM
UnstableBoy's Avatar
I have rocked the bike onto the kickstand to pivot the bike in one spot... pretty strong.
Reverend Unstable Boy
http://www.youtube.com/user/RevUnstableBoy
https://www.facebook.com/RevUnstableBoy
UnstableBoy is offline
post #10 of 19 Old 11-18-2013, 12:08 PM
Ditto, I'm 230 plus gear
2013 V-Strom 650 Adventure (commuting machine)
2012 Kymco Like 200i (for fun):biggrinjester:
JPilot is offline
