ABS Warning light. ABS non-Functioning - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 78 Old 11-15-2013, 12:15 PM Thread Starter
V-Tom's Avatar
I noticed over the last few months that after starting the ABS light would flicker a bit on my 2012 DL650. (Wee2)
I didn't really think much of it as it went out as soon as I started moving. Last night the light flickered a bit when riding and then came on steadily. I did what any self respecting rider woudl do and killed the ignition and then re-started and the light stayed off.. for about 5 minutes. It started flickering and I noiticed (whiel riding at about 55 mph) that if I let the engine idle the steady light would turn to flickering. When I put it back up to speed it woudl be on steadily. When I got to a sutable area I checked the ABS on the rear brake and it was non-functional.
This morning I started it and rode into work. After five or 10 minutes of riding the ABS light came on again and stayed on. I didn't try any little tests this AM while riding but may on the way home again.
I know that most often ABS warnings relate to sensors failing or bad connections on them. This wouldnt surprise me seeing as I ride in lots of salt and crap, and Tuesday eve was in solid snow for a bit. The light flikering while idling and full brightness at highway speed makes me thinkk I should look at voltage levels as well.
Any thoughts? Where should I start looking? Bike has about 50,300 miles on it.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #2 of 78 Old 11-15-2013, 12:38 PM
First check the sensors and wheel ring holes. If those are clean, try some ACF50 on the ABS connections, especially the pump connections behind the shock.
post #3 of 78 Old 11-15-2013, 01:11 PM
enumclaw's Avatar
When mine started doing similar whacky things a couple years ago, I found one of the bolts for the sensor had worked its way loose a few threads. In my case it was the rear wheel.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #4 of 78 Old 11-16-2013, 09:06 AM
when i was doing mods on my K8 a few years back - i find that the ABS system really like to see a clean earth contact- something loose somewhere, maybe at the fuse holder/connection
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #5 of 78 Old 11-16-2013, 09:32 AM Thread Starter
V-Tom's Avatar
I'm going to try and give it a good going over tomorrow. On the surface no bolts were loose. I'll give it a good wash and make sure the sensor wheel is clean. I'll check connections as wel.
Ironicaly it didn't do it this morning.
..Tom
V-Tom is offline
post #6 of 78 Old 11-20-2013, 12:53 PM Thread Starter
V-Tom's Avatar
I did 't get a chance to do much on the weekend. Had lots of chores to do and when I fiannaly started really looking at it the weather turned to snow and freezing rain (and I don't have a garage anymore.)
About all I could do was to clean the bike to make sure there wasn't crud on the sensor wheels and to undo and then tighten up the sensors. They were fine.
One other symptom: when I first ride, before the sensor light comes on, the system seems to think that the front wheel has locked up as it pulses the ABS for a moment before letting the brake work (non-ABS) normally. This generally only happens shortly after starting, after less than a minute it doesnt happen anymore. The first few stops are slow speed ones so I don't know if it would act differently at higher speeds. Shortly after that the ABS light comes on.
With the system thinking the front wheel has locked indicate that I should be looking hard at the front brake sensor connections and possibly the sensor itself?
Thanks,
..Tom
V-Tom is offline
post #7 of 78 Old 11-20-2013, 01:57 PM
That would be my take on it plus making sure the holes in the ring were free of crud.
post #8 of 78 Old 11-20-2013, 09:53 PM Thread Starter
V-Tom's Avatar
ABS appears fixed!!
I didn't touch anything that is directly on the ABS. I had noticed my rear brake pedal seemed a bit wooden and figured the linkage needed a bit of lube after my heavy ride in the snow last week plus all the salt and crap. I was talking with a tech at my work who loves bikes about what pub I shoud use and next thing he brings it in the shop and basically rinses out the brake pivot point with some fancy stuff that really is not tht different than WD40. He ringed the stuff into a container and showed me all the crap that came out. When done the pedal moved normally as it should.
My ride home tonight is about 50 miles. Generally the ABS light comes on in a mile or two.. No light tonight! I tried locking up the rear at a few points and got the wonderful ABS feel in the pedal.
Can it be that the pedal not releasing properly caused the ABS computer to think something is wrong and shut things down?
Il see in the morning if it stays fixed.
..Tom
mpom likes this.
V-Tom is offline
post #9 of 78 Old 11-21-2013, 12:01 AM
If your brake light was on for extended periods of time, I can see that being a problem. Now grease the pivot. Oil doesn't last long. Or do this.
post #10 of 78 Old 06-15-2015, 11:02 AM
Don_T's Avatar
Another ABS Warning light/ABS non-Functioning issue.
I have just returned from a 3 weeks trip around Europe during which the ABS issue occurred - the bike had 76.500 km on the clock at the time.
I was riding in heavy rain on dirty roads when the ABS warning light came on (I wasn't breaking at the time).
The warning light stayed on for the rest of the day and the following 2 days of riding (in dry conditions).
The sensors and wheel ring holes didn't look that dirty and the bolts holding the sensors was as they should be.
After 3 days I had the opportunity to dig out this thread and afterwards I thoroughly cleaned the sensors and wheel ring holes and cleaned/lubed the brake pivot point - that didn't make any difference.
After another 2 days of riding on dry roads the warning light went out after a fuel stop and the ABS functioned again.
The last day on the trip (3 days ago) we hit a few showers and the ABS warning light came on again and stay on.
When I got home I thoroughly cleaned the bike and lubed all the moving parts. Besides that I disconnected and sprayed the pump connections behind the shock with a lubricant for electrical connections before putting it back in place.
That didn't help - the warning light was still on and the ABS non-functioning.
Today after 2 days of riding in dry conditions the warning light went out and the ABS functions again.
I have a sneaky suspicion that the issue will occur again the next time I ride in wet conditions.
Any suggestions (greywolf?) about what I can do to prevent that from happening?
By the way - V-Tom did the problem reoccur on your bike or did the cleaning do the trick permanently?
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
