What is this part? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 11-10-2013, 03:07 PM Thread Starter
WeePilot's Avatar
What is this part?
What are the parts pictured below and how do I get the rust off of them? It's the cylinder shape with the silver color metal on each end.
File Type: jpg ImageUploadedByMO Free1384113933.348867.jpg (31.2 KB, 117 views)
WeePilot is offline
post #2 of 11 Old 11-10-2013, 04:22 PM
D.T.'s Avatar
That's the ignition coil. Not sure why it's rusty...
Steel wool should get it off or a wire brush.
D.T. is offline
post #3 of 11 Old 11-10-2013, 04:23 PM
Those are your ignition coils. You basically leave them alone. I've never heard of a coil failure due to rust on the iron plates. They just strengthen the magnetic field.
post #4 of 11 Old 11-11-2013, 08:13 AM Thread Starter
WeePilot's Avatar
Has anyone else had a rust problem like this?
WeePilot is offline
post #5 of 11 Old 11-11-2013, 08:31 AM
chicago's Avatar
Looks just like mine.
chicago is offline
post #6 of 11 Old 11-11-2013, 08:35 AM
Kenscoots's Avatar
Just like mine too.
Kenscoots is offline
post #7 of 11 Old 11-11-2013, 10:42 AM
I think you'll find just about everybody's looks like that.
post #8 of 11 Old 11-12-2013, 03:33 PM
Just went and looked, mine are the same.
ronhawk62 is offline
post #9 of 11 Old 11-12-2013, 04:17 PM
1 Wheel Drive's Avatar
It's rusty because these coils are wound around a laminated iron core and the manufacturer did not bother to paint or otherwise protect it from rusting. It does not affect it's ability to generate a spark, but if the rust offends you, you could coat the rusty core with some sort of paint. Just be sure that that the mounting / contact area is left bare as I believe it is a frame grounding point for the coil.
1 Wheel Drive is offline
post #10 of 11 Old 11-13-2013, 12:44 AM
MeefZah's Avatar
Normal.
MeefZah is offline
