16 tooth sprocket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 72 Old 11-09-2013, 11:10 AM Thread Starter
Toytech's Avatar
16 tooth sprocket
Greetings,
I just returned from a 4 day trip that involved far too much highway time. The engine just feels too frantic at a indicated 75mph. So the solution must be here in Stromtrooper.
Somewhere in this forum is a post about replacing the front sprocket with a 16 tooth count. I looked and could not find the all important post with the OE part number for the sprocket. I do want to retain the rubber damper and genuine quality part. I recall it might be a Gixxer sprocket? Sooo... can anybody confirm part number and bike application? Greywolf, I suspect you supplied the correct OE number. Additionally do I need a replacement nut and washer? Left hand or right hand threads and torque specs.
Thanks in advance.
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #2 of 72 Old 11-09-2013, 02:15 PM
DRD
27510-20A10 Oem Suzuki 16t front sprocket. $36.81 on parts monster.
DRD
2013 Blue DL650
DRD is offline
post #3 of 72 Old 11-09-2013, 02:32 PM
Originally Posted by DRD View Post
27510-20A10
That is the correct part from a GSX-R600. The nut can be reused indefinitely unless marred. The toothed washer can be reused about three times if carefully straightened and re-bent in a different place. 09167-25028 is the washer number. The book says 105lb-ft but use 83ft-lb, the spec for exactly the same nut on the DL1000. The spec is for blue Loctite too.
post #4 of 72 Old 11-09-2013, 05:10 PM
16/43 works great on the Vee. Not sure how it would play out on the Wee. :beatnik:
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #5 of 72 Old 11-09-2013, 06:13 PM Thread Starter
Toytech's Avatar
Fabulous. On my way to the Stealer now to order it.
Toytech is offline
post #6 of 72 Old 11-09-2013, 06:52 PM
chicago's Avatar
Originally Posted by Toytech View Post
Greetings,
Thanks in advance.
I take it you've seen this.....
https://www.stromtrooper.com/dl650-20...-sprocket.html
chicago is offline
post #7 of 72 Old 11-09-2013, 09:02 PM Thread Starter
Toytech's Avatar
Yes I read the 14 tooth post. My needs would be the 16 tooth sprocket. I want to reduce the hurried feel of the engine. For the off road adventures I would go on it would be just dirt roads, no monster single tracks and dirt hill climbs.
Toytech is offline
post #8 of 72 Old 11-10-2013, 02:33 AM
And the 16T means an accurate speedo :mrgreen:
Oop North John is offline
post #9 of 72 Old 11-10-2013, 08:03 AM
Frantic?
When I'm at 75 indicated my bike is at 5k RPM. It's still at the bottom of the revs.
'13DL650-A
teknik is offline
post #10 of 72 Old 11-10-2013, 10:08 AM Thread Starter
Toytech's Avatar
I will take the accurate speedo reading. As it is right now I rely on my GPS for accurate numbers. FYI Speedo indicated 75MPH translates into 71MPH on the GPS.
Thank you all of your help and information.
Toytech is offline
