What color is the low-beam wire? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-08-2013, 08:58 PM Thread Starter
Does anyone know which color wire to tap to trigger a relay from the low-beam headlight circuit? I am installing fog lights on a relay. In my state (PA) they can only be run with the low-beam headlights--so I want to trigger the relay off of the low-beam circuit. The wiring diagram is almost unreadable but it seems there are Y (yellow) and B/Bl (black w/blue tracer) wires to both headlights, along with B/W(black w/white tracer) which I presume is the ground. I'm trying to figure out if the low-beam lead is the Y or the B/Bl . Thanks.
Sabreman is offline
post #2 of 5 Old 11-08-2013, 09:12 PM
B/Bl is low beam hot.
post #3 of 5 Old 11-08-2013, 09:17 PM Thread Starter
Thank you Greywolf--- I just saw you answered the same question in September on a similar thread, sorry my search did not turn that up sooner. Appreciate your prompt reply !
Sabreman is offline
post #4 of 5 Old 11-09-2013, 08:42 AM Thread Starter
One follow-up question----am I correct that the low-beam lead will cut out when the high-beams are switched on? Or does the bulb draw from both low and high beam positive leads when the brights are on? I need my fogs to cut out when high beams are on.
Sabreman is offline
post #5 of 5 Old 11-09-2013, 09:53 AM
That's correct.
