Lowering question AGAIN - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-08-2013, 07:05 PM Thread Starter
Sorry to bring up the done to death issue , i've searched for the answer to this one and cannot find it . Anyhow due to short leg syndrome , on uneven ground , putting my foot down, it did'nt reach the bike went past the point of no return and , i managed to lower it gently , but not without, holding and taking the 200 odd kilo weight all on my forearm .
Lucky my top half is built like a gorrila , so i did'nt hurt myself , but i thought i had tore the muscle in the forearm , and thought stuff it , i'm gonna get some lowering links .
Anyway , i went to order some kouba ,links , only to be sent to another site if i'm paying with credit card , i went there and they only seem to sell the 1.25 inch links .
So after reading about it a lot , i understand front and rear should be the same , , so if my front can only be lowered 3/4 of an inch (ABS) ,
WHATS THE SCENARIO IF I BUY THE 1 1/4 links and theres a difference . between the front and rear , will the 1/2 inch diff matter or will it not .
Or shall i just go buy soupys, and adjust them , or whatever else is around .
Lowering is not something i really want to do but , heh i can see myself dropping the bike on uneven ground so it may be no choice .
coneye is offline
post #2 of 5 Old 11-08-2013, 07:53 PM
If lowering is something you are reluctant to do, go with 3/4" front and back. You can also lower the seat. Look at Raising and Lowering Links - AdventureTech, LLC. for more choices.
post #3 of 5 Old 11-08-2013, 08:37 PM Thread Starter
Thanks for that Greywolf ,,, that site has some other stuff i'll order has well , , which are the best alluminium or steel likns , the difference in price is minimal so its the best i want ,
cheers
coneye is offline
post #4 of 5 Old 11-10-2013, 01:20 AM
650wee's Avatar
aluminium is lighter and does not rust. steel is stronger but rusts if not coated properly
650wee is offline
post #5 of 5 Old 11-10-2013, 08:21 AM
Oly
Oly's Avatar
I'm not sure why the Kuoba Link site wouldn't cooperate for you. It worked just fine for me.
I lowered the front and rear 3/4 of an inch. Makes the bike so much better - for me.
I'll make a wild guess on the next two questions -
no clearance issues at all with the Akrapovic exhaust.
no idea on lowering / aftermarket exhaust clearance if there is a centerstand involved.
IBA # 54253
Oly is offline
