Running the 650 as a single cylinder? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 11-07-2013, 06:19 PM Thread Starter
Has anyone ever experienced a fuel injection or ignition failure on one cylinder?
Would the engine even hold an idle?
Will codes stored in the ECU clear once you repair the problem?
I have an idea where I'd intentionally want to run the V-Strom as a single cylinder 325 for a very short period. I'd want to kill both the ignition AND fuel injector to one cylinder.
2012 DL650 Adventure - Black
OEM Hand guards, OEM Heated grips, Stroma Center Stand and Shifter, SV Racing Frame and Swingarm sliders, Eastern Beaver power distribution, Skene Visibility Lights
Pele2048 is offline
post #2 of 14 Old 11-07-2013, 07:00 PM
All you have to do is unplug the electrical connection to a fuel injector. You could disconnect a coil too but a wasted spark isn't going to do anything. I'm not sure whether it would idle with hands off the throttle. Once reconnected, the FI would disappear but a code would be stored as a former problem. A Suzuki SDS tool or HealTech OBD tool would be needed to read or clear the old code(s).
post #3 of 14 Old 11-07-2013, 07:21 PM
kiwi_outdoors's Avatar
unplug
you mean unplug the electrical cable to the injector, not the fuel rail, correct?
kiwi_outdoors is offline
post #4 of 14 Old 11-07-2013, 07:34 PM
Right. It's way easier to prevent the injector from opening than to plug the fuel line. Just disconnecting the fuel line will spray fuel all over.
post #5 of 14 Old 11-07-2013, 08:48 PM
I bet it will run as smooth as that Enfield I test rode. Wunnerful!
The again it do have a lot of balanced reciprocating mass. Might just be down on power.
notacop is online now
post #6 of 14 Old 11-07-2013, 09:21 PM Thread Starter
Not trying to run it anywhere... Just idling stationary and not even for that long. 5-10 minutes at the most.
Pele2048 is offline
post #7 of 14 Old 11-08-2013, 06:03 PM
I have a tire inflator that plugs into a spark plug hole. I've had my beemer pump up a tire. It's lumpy but a well tuned engine can run on one cylinder.
post #8 of 14 Old 11-08-2013, 06:04 PM
I had a Heritage Softtail running on one cylinder briefly. It barely was able to get around. I'd imagine most twins would be the same.
pacaver is offline
post #9 of 14 Old 11-08-2013, 08:44 PM Thread Starter
Shhh.
Yep, that was my idea.
I was looking for a small air pump to keep under the seat, since... you know... you can't carry a spare or very easily change it out on a motorcycle.
Then, I realized that I already have an air pump on the bike.
When talking about improving engine efficiency, everyone always says improve intake and exhaust to make it breathe better... Everyone always says that an engine is a big air pump.
Figure, all I need is either the adapter off of a compression tester or an old spark plug drilled out, a check valve, a pressure relief valve, and a short length of air hose with an air chuck on the end. Shouldn't be much larger than the stock tool kit all curled up.
I just don't want to pump gasoline into the tire, hence I want to kill the injector.
Pele2048 is offline
post #10 of 14 Old 11-08-2013, 10:22 PM
Vstrom N Me's Avatar
I don't know that I would do that. Airing up a tire cant be that hard - even by hand
Vstrom N Me is offline
