"Accessory Adapter" from Eastern Beaver - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-04-2013, 04:46 PM Thread Starter
Has anyone used the "accessory adapter" for the Glee, which is what he calls our auxillary outlet? Is it plug and play, or do you need to solder the wires on the other end to a power jack (powerlet, cigarette sytle, SAE, etc., depending on your device)? I use a cigarette style plug hooked up to the battery to charge both my phone and GPS, but the wire is a PITA. Obviously, I'm an idiot when it comes to electronics (among other things), so your patience is appreciated.
Thanks,
Keith
kmkindred is offline
post #2 of 6 Old 11-04-2013, 05:10 PM
VSrider's Avatar
One end plugs into the accessory jack inside the right fairing. (pull out the plug first) The other end is just a pigtail. I used solderless crimp connectors with heat shrink sleeves or you can solder.
VSrider is offline
post #3 of 6 Old 11-04-2013, 05:12 PM
jrnyer's Avatar
Mine from EB is plug and play
jrnyer is offline
post #4 of 6 Old 11-04-2013, 10:12 PM Thread Starter
Thanks for quick replies - much appreciated
post #5 of 6 Old 11-04-2013, 10:51 PM
oink's Avatar
If you have one in your area, West Marine has a pretty good selection of terminals and connectors with heat shrink jackets with adhesive lining, as well as heat shrink tubing with the adhesive lining. That's the way to go, crimping or soldering.
oink is offline
post #6 of 6 Old 11-05-2013, 03:34 PM
I just bought two sets of pins (in case of mistakes) from EB and fitted them into the blank connector. Be careful for solder runs into the female pins (glad I went for two sets). One hour to solder the pins and fit the accessory socket.
Stobie is offline
