2013 Wee. Can I install an adj 2" riser? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 11-03-2013, 02:12 PM Thread Starter
DesertWee-Strom's Avatar
Will I need to replace or reroute any cables?
2004 BMW 1150 GS Adventure
2012 Suzuki DRZ 400s
2013 Wee-Strom
DesertWee-Strom is offline
post #2 of 11 Old 11-03-2013, 03:42 PM Thread Starter
Tusk makes a 30mm riser which looks good comes in 2 sizes 7/8 or 1"1/8. Which one do I need for '13 Wee?
2013 Wee-Strom
post #3 of 11 Old 11-03-2013, 03:47 PM
JohnnyReb's Avatar
I just finished installing the 2" adjustable Rox Risers on my 2013 dl650. On the left side of handlebar I removed the wires from the clip but left the clutch cable in the clip. On the right side I removed both the brake line & throttle cables from the clip. Also removed the cable tie from the throttle cables. At an idle there was no change of RPM's lock to lock & nothing seemed to be binding, although I will be purchasing the extended SS brake line kit & the electrical extensions. Took her out for quick ride & oh, what a difference, I can sit up straight with arms relaxed.
Which Sand Box are you in?
2013 DL650
You are never lost,
just temporarily misplaced.
JohnnyReb is offline
post #4 of 11 Old 11-03-2013, 03:52 PM
zekester63's Avatar
7/8" for stock bars. That's what I put on my '13, and although a bit snug, all the cables are fine. I scuffed the risers up with some fine sandpaper and painted them black. I think they look good and definitely help.
zekester63 is offline
post #5 of 11 Old 11-03-2013, 07:20 PM
I raised mine 1 inch with no problems with cables, brake lines etc. It does take up the slack in the brake line, but works fine. From what I've read and the consensus on this issue, seems to be that anything much over that involves lengthing the brake lines.
So I'll go with the consensus and you should expect to have to lengthen the brake line from the master cylinder down to the junction box.
cycleman is offline
post #6 of 11 Old 11-04-2013, 12:12 PM Thread Starter
Thanks for the info
I'm in the Mojave Desert So Cal
2013 Wee-Strom
post #7 of 11 Old 11-04-2013, 12:21 PM Thread Starter
Thanks for the pic I'm going to order the 7/8 Tusk 30mm
2013 Wee-Strom
post #8 of 11 Old 11-04-2013, 02:20 PM Thread Starter
I just ordered some 30mm from Rocky Mtn $19.99 I like the way yours look in black. What type of paint did you use?
2013 Wee-Strom
post #9 of 11 Old 11-04-2013, 02:35 PM
Did I read somewhere that the abs limits the riser choices?
keithert is offline
post #10 of 11 Old 11-04-2013, 03:11 PM
zekester63's Avatar
I use Krylon Fusion black for all that stuff. Can't remember if I used gloss or satin though.
