2013 DL650 Hard Bags Rattle No More! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 10-19-2013, 07:00 PM Thread Starter
pierpontcraig's Avatar
For those of you who are looking for a solution to you hard bags rattling, Here's a $6 fix. West Marine has the shrink tubing for this 10 minute fix. Should last a bit longer than electrical tape. but that works too.
Good luck,
Craig
pierpontcraig is offline
post #2 of 10 Old 10-19-2013, 07:12 PM
mountainpete's Avatar
Heat shrink - smart!
2012 DL650 EXP
Designed for outdoor use
mountainpete is offline
post #3 of 10 Old 10-19-2013, 07:50 PM
dravnx's Avatar
Even simpler and cheaper technique. Adjust the latch properly. Loosen the two bolts that secure the latch hook to the rack, move the hook a little bit forward, tighten the bolts and try it. Takes the rattle right out.
Sent from Motorcycle.com App
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #4 of 10 Old 10-19-2013, 07:52 PM
njbill's Avatar
Mine do not rattle... yet. I will keep this in mind when things loosen-up. Thanks!
njbill is offline
post #5 of 10 Old 10-19-2013, 09:33 PM
I used to use plastic tubing on the round tubing. Slit the stuff along the long side and put it over the tubing to make up the slop in the latching mechanism.
Whatever works best for you will do the job!
post #6 of 10 Old 10-20-2013, 09:48 AM
same here, no rattle whatsoever
'13DL650-A
teknik is offline
post #7 of 10 Old 10-20-2013, 01:26 PM
Geology Rocks
The shrink wrap is a great idea, but I just adjusted all the clips and made it so when strapping them down it was firm and tight. No rattles after 3000 miles.
post #8 of 10 Old 10-22-2013, 07:58 AM
zildjian's Avatar
Locks not Bags
On mine, its not the boxs but the locks. The cylinder that turns when you insert the key vibrates like crazy, particularly on my top box. If I lock them, then they don't vibrate because there is enough pressure to prevent the vibrations. But I often roll with them unlocked as my bike is almost always parked in a safe place. I know I know, I should just keep them locked all the time.
zildjian is offline
post #9 of 10 Old 06-11-2017, 07:03 PM
Pel
Bicycle Tube
Mine rattle where they mount and always have, even when tight. A quick and easy fix is to cut a piece of bicycle inner tube and slide it over. Now it's like having rubber mounted luggage. Easy and free.
Pel is offline
post #10 of 10 Old 06-11-2017, 08:00 PM
cpd419's Avatar
No rattle here 13000 mls
2013 DL650
cpd419 is offline
