Oil capacity? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-17-2013, 05:59 AM Thread Starter
Oil capacity?
Good day all,
On my DR650, I throw 2 quarts/liters in when I change my oil along with the filter. The specs call for for more than that, 2400ml or something, not sure, but 2 bottles of oil is the perfect amount. Does our Vstrom 650 take a different amount than indicated in the specs?
Thanks
dljocky is offline
post #2 of 11 Old 10-17-2013, 06:09 AM
kitesurfer's Avatar
2.9 quarts, off the top of my head.
2012 DL650
U.S. NAVY, RETIRED
kitesurfer is offline
post #3 of 11 Old 10-17-2013, 06:20 AM
BMiracleTX's Avatar
Originally Posted by dljocky View Post
Good day all,
Thanks
2 quarts is too low even without changing the filter, and way too low with a filter change. Fill it with what the manual recommends.
BMiracleTX is offline
post #4 of 11 Old 10-17-2013, 10:49 AM
RCinNC's Avatar
A 2012 DL650 takes 2.9 quarts with a filter change, and 2.5 quarts without a filter change. That's from page 7-26 of the owner's manual.
RCinNC is offline
post #5 of 11 Old 10-17-2013, 10:59 AM Thread Starter
Thanks all.
dljocky is offline
post #6 of 11 Old 10-18-2013, 12:17 AM
If I understand your post correctly DlJocky, you are concerned that the specified oil capacity for your V-Strom might be inaccurate because it is for your DR650 (not DL) and they are both Suzuki products.
In my experience (I do all my own oil changes) the amount specified in the owners manual is accurate and I put in exactly that amount.
Hope this helps.
Mike
Idaho
www.rtwrider.net
liketoride2 is offline
post #7 of 11 Old 10-18-2013, 03:54 AM Thread Starter
Thanks Mike.
Yes, that is what I was trying to say. I appreciate all the replies.
dljocky is offline
post #8 of 11 Old 10-18-2013, 04:20 AM
Why don't you use the sight-glass on the right side of the engine for getting your oil level correct? Personally, with the Wee, I like to add fresh oil to the filter before installation so that I can avoid low oil pressure upon start-up. There has been some discussion about doing this but it seems like a good idea and can't hurt.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #9 of 11 Old 10-18-2013, 09:41 AM
BMiracleTX's Avatar
I always add oil to the filter on both bikes and cars/trucks and yes the manual is correct.
2012 DL650A Adventure, Yoshimura R-77 3/4 exhaust, Sargent World Sport Performance Plus seat, ProTaper SE Raptor bars, SW-Motech 25mm risers, ProGrip Grips, Suzuki handguards, Tuono mirrors, Givi skid plate, Adventure Tech fork brace, GPS mount, peg lowering kit, auxiliary power shelf, SW-Motech convertible foot pegs, SW-Motech extended shift lever, SVRacing frame sliders, Garmin Zumo 660, MRA Xcreen, Michelin Pilot Road 3 Trails, Eastern Beaver headlight relay, Coocase V37
Currently in the United Kingdom and looking for great rides. PM if you have suggestions.
post #10 of 11 Old 10-18-2013, 10:13 AM Thread Starter
Good input.
Thanks
dljocky is offline
