Slipping from 1st to neutral - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 10-14-2013, 07:23 PM Thread Starter
texastromrider's Avatar
I am new to this forum so first of all, hello to everyone. I've been riding my 2012 DL650 for almost a year and have around 5500 miles on it. Recently when in first gear and moving I preload the gear lever it slips into neutral without pulling in the clutch. This has happened twice in the last week or so and i cant recall it happening before. Is this common and/or normal, or should I get it checked out? Thanks in advance for any feedback.
texastromrider is offline
post #2 of 9 Old 10-14-2013, 07:26 PM
Well if you're pushing up on the lever, it's going to go into neutral. Don't "pre-load" the lever would be my recommendation.
2009 WR250R
2004 DL650
1978 KZ650
1966 CB160
1964 CA95
Noobens is offline
post #3 of 9 Old 10-14-2013, 07:34 PM
You only want to preload the shift lever if you are planning on shifting, otherwise leave it alone and don't put any pressure on the shift lever.
cycleman is offline
post #4 of 9 Old 10-14-2013, 10:51 PM
Tydive's Avatar
Upshifting without the clutch is a common practice. Gently preload the clutch lever, roll off throttle, it will smoothly slip into the next gear.
Downshift works the same way, only you press down on the gear shifter and blip the throttle (add more gas briefly) to slip into the lower gear.
This works on all motorcycles as far as I know.
[URL="https://www.stromtrooper.com/ride-reports-route-sheets/211578-california-idaho-lolo-motorway-magruder.html"]California to Idaho Adventure style[/URL]
[URL=http://bayarearidersforum.com/forums/showthread.php?t=478959]Taking America by Strom 2015[/URL]
Timing is everything.
Tydive is offline
post #5 of 9 Old 10-15-2013, 10:36 AM
Toytech's Avatar
First question is why pre-load on a decently slick shifting transmission? It's not a Motoguzzi.
Second question is how is your chain adjustment? I was on a ride Saturday that was complaining about shifting issues. Riding next to him I was able to look down at his chain and moved like a wave in the ocean. Adjusted his last night and his test ride results were "problem fixed".
Just my 2 "P".
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #6 of 9 Old 10-15-2013, 10:44 AM
BMiracleTX's Avatar
Completely normal. I actually do alot of clutchless upshifting when I am feeling lazy or "opening it up". It is easier to preload, then slightly roll off throttle and roll back on when acclerating hard. The 'Strom transmission does pretty easy clutchless upshifts, but so far hands down the easiest bike I have ever done it on was my 2010 Kawasaki Z1000 naked bike... that bike had such a sweet transmission...
2012 DL650A Adventure, Yoshimura R-77 3/4 exhaust, Sargent World Sport Performance Plus seat, ProTaper SE Raptor bars, SW-Motech 25mm risers, ProGrip Grips, Suzuki handguards, Tuono mirrors, Givi skid plate, Adventure Tech fork brace, GPS mount, peg lowering kit, auxiliary power shelf, SW-Motech convertible foot pegs, SW-Motech extended shift lever, SVRacing frame sliders, Garmin Zumo 660, MRA Xcreen, Michelin Pilot Road 3 Trails, Eastern Beaver headlight relay, Coocase V37
Currently in the United Kingdom and looking for great rides. PM if you have suggestions.
BMiracleTX is offline
post #7 of 9 Old 10-15-2013, 01:41 PM
check your chain and also did you get new boots?
I was popping it into second until I broken my new boots in.
'13DL650-A
teknik is offline
post #8 of 9 Old 10-15-2013, 01:49 PM
Perfectly normal if you happened to roll off the throttle at the moment it did this.
You should have to apply a good bit of force to get it to do it while under acceleration.
There is a point between acceleration and completely off the throttle that the transmission will shift very easily as there is no load against it....just like when the clutch lever is pulled.
realshelby is offline
post #9 of 9 Old 10-15-2013, 02:20 PM
tmcgee's Avatar
While you're at it, adjust your clutch cable. Page 7-28 in the Owner Manual.
tmcgee is offline
