Bar Snake install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 10-13-2013, 03:24 PM Thread Starter
JohnnyReb's Avatar
Bar Snake install
What can I expect when I take the bar end screw all the way out? I'm seeing a rubber plug behind the actual bar end; is there anything else in there? I'm assuming that once the bar snake is in the handlebar, the rubber plug & bar ends are re-installed. Am I correct in my thinking? Any tips or suggestions will be appreciated. Thanks in advance,,,JC
2013 DL650
You are never lost,
just temporarily misplaced.
JohnnyReb is offline
post #2 of 3 Old 10-13-2013, 04:49 PM
BMiracleTX's Avatar
Well.... you should never remove the bar end and leave the rubber plug inside the handlebar. The captive nut can sometimes fall out of the plug and then you are screwed. When removing the bar ends, simpy loosen the bolt and remove the entire assembly including the rubber plug and nut. You will have to work it out, but the whole thing will come out.
When putting your screw back in, don't force it and push the nut out of the rubber piece! Slowly screw it back in to capure the nut... otherwise it wil be a pian in the rear to get the nut and rubber piece out.
2012 DL650A Adventure, Yoshimura R-77 3/4 exhaust, Sargent World Sport Performance Plus seat, ProTaper SE Raptor bars, SW-Motech 25mm risers, ProGrip Grips, Suzuki handguards, Tuono mirrors, Givi skid plate, Adventure Tech fork brace, GPS mount, peg lowering kit, auxiliary power shelf, SW-Motech convertible foot pegs, SW-Motech extended shift lever, SVRacing frame sliders, Garmin Zumo 660, MRA Xcreen, Michelin Pilot Road 3 Trails, Eastern Beaver headlight relay, Coocase V37
Currently in the United Kingdom and looking for great rides. PM if you have suggestions.
BMiracleTX is offline
post #3 of 3 Old 10-13-2013, 05:13 PM
VSrider's Avatar
This thread has pointers on removing the bar end weights.
https://www.stromtrooper.com/dl650-20...questions.html
VSrider is offline
