H4 Headlight Relay - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-12-2013, 07:35 PM Thread Starter
JohnnyReb's Avatar
H4 Headlight Relay
Is this really needed on a bone stock bike,,,,meaning the bike has no electrical add ons such as additional lights. Eastern Beaver seems to think so. Just wondering how many are installing this headlight relay.
2013 DL650
You are never lost,
just temporarily misplaced.
JohnnyReb is offline
post #2 of 11 Old 10-12-2013, 08:07 PM
Sadly, yes. It would cost Suzuki very little to do it right but that's what we get with a budget bike. Full headlight current goes thru the switch instead of relays. Switches will burn up eventually at a high failure rate. I think there's a survey somewhere here with numbers. I'm adding relays to our 2012's as one of this winter's projects.
dkayak1 is offline
post #3 of 11 Old 10-12-2013, 08:30 PM
Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums - View Poll Results
I'd recommend relays for brighter lights and longer lasting contacts and connectors.
post #4 of 11 Old 10-13-2013, 10:39 AM
You normally only put a relay into a circuit to protect the switch because the manufacturer can then build the headlight switch with lighter components and save some money.
If the manufacture builds the switch to handle the current draw of the stock headlights than there is really no issue.
Nothing wrong with putting a relay in the circuit if you want, but its not really necessary if you are staying with stock lighting. If you up that then a relay would make sense.
Heck my 71 BMW R bike doesn't even have any fuses, let alone a headlight relay and all the switches still work fine.
It boils down to the design of the electrical system.
cycleman is offline
post #5 of 11 Old 10-13-2013, 10:42 AM
Quite true and well said. The problem is that Suzuki did not.
dkayak1 is offline
post #6 of 11 Old 10-13-2013, 10:53 AM
I've worked on an R75/5 Beemer. The electrical system is not great. The headlight has less power than one V-Strom headlight.
post #7 of 11 Old 10-13-2013, 11:17 AM
tmcgee's Avatar
Shorter bulb life too, at least that's how it was on my '07 and '05 -- haven't had the relays installed on the '12 for more than a few months, so dunno about those bulbs yet.
tmcgee is offline
post #8 of 11 Old 10-13-2013, 12:41 PM
chicago's Avatar
Plenty of reports here of people having issues with their lights traced to damaged connectors and/or switches. Some have no issues. Installing a relay would take the load off these components. I think of it as cheap insurance.
Re shorter bulb life.....true no doubt though it hasn't been an issue for me in thousands of miles.
chicago is offline
post #9 of 11 Old 10-14-2013, 08:04 PM
There seems to be some confusion on what a relay actually is.
On a relay you will have a main voltage say 20 amp coming into one pin of the relay, (we'll call this pin 1) , and then another pin that goes to the headlight, horn or whatever is going to be the source, ( we'll call this pin 2). You will have 2 other pins, one goes to the switch ( pin 3 ) and the other ( pin 4 ) likely goes to ground. When you push the light button, starter button, horn etc ( pin 3 ) it sends it to ground which completes the circuit and then allows current to flow between pins 1 & 2 ),.
Another good example of this is on a water cooled engine ( including motorcycles that have a fan ). When the temp sensor in the block, rad or wherever it is, reaches its set temperature range, then it closes the circuit ( shorts it to ground ) and the fan will start. Most if not all of these temperature sensors are protected by a relay of some description.
A properly designed switch, and I don't believe that Suzuki or any other manufacture would design a switch that wouldn't handle its rated load, is not going to cause problems. In the example of the fan switch above the stock fan sensor was designed ( this was a first generation gold wing ) to handle the current draw and rarely ever caused a problem. If you wanted to use a car type sensor ( different temp range etc ) then you had to protect it with a relay, otherwise it would fail. The reason was that it was not designed to operate at the high current draw of the the fan motor. However the stock gold wing temp sensor was.
There are many good examples on the web of relays and how they work for those that are interested.
cycleman is offline
post #10 of 11 Old 10-14-2013, 08:08 PM
Here are some people who would argue the stock design is lacking. https://www.stromtrooper.com/informat...e-problem.html
