Little help. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-10-2013, 01:18 PM
Geology Rocks
Little help.
So I am installing my gps set up on the new bike. I got the harness from eastern beaver and set it up to my 12v. The accessory port on the front right isnt giving power. Does it need a fuse? What am i missing?
post #2 of 11 Old 10-10-2013, 01:23 PM
Is the ignition on? It is a switched power supply. I used the EB harness and did add a low amp fuse.
eff naked teeth is offline
post #3 of 11 Old 10-10-2013, 01:27 PM
Geology Rocks
The plug not getting any power. Egnition is on. When i used a test light it got no power
post #4 of 11 Old 10-10-2013, 01:32 PM
Kelly2012's Avatar
Check the 10A ignition fuse under the seat.
Kelly2012 is offline
post #5 of 11 Old 10-10-2013, 01:36 PM
V-Tom's Avatar
What kind of GPS?
If it is a Zumo then you should just take the harness directly to the Battery.
If it is something else then I guess it depends. For my previous GPS (Garmin 60Cx) I wired a cigarette Lighter directly to the battery. (Of course in all cases use a fuse inline!)
..Tom
SMIDSY detailed report.
V-Tom is online now
post #6 of 11 Old 10-10-2013, 02:33 PM
Geology Rocks
Power all the way.
The ignition was blown so thanks! I leave saturday for my ride.
Thanks
post #7 of 11 Old 10-10-2013, 03:09 PM
Geology Rocks
Ok....so the cigarette lighter is getting power but it wont transfer to the gps.
post #8 of 11 Old 10-10-2013, 03:18 PM
DougInKY's Avatar
Send a message via AIM to DougInKY Send a message via Skype™ to DougInKY
My GPS requires 5 volts DC, not 12 volts DC. You need to check yours to see what voltage it needs.
2007 Wee-Strom (*SOLD*)
2009 Suzuki Burgman 650 Executive
1980 Honda Express (my toy!)
DougInKY is offline
post #9 of 11 Old 10-10-2013, 04:38 PM
Kelly2012's Avatar
Originally Posted by Geology Rocks View Post
Power all the way.
Thanks
Same thing happened to me last week, but I was on the freeway in rush hour. I had temporarily adhered a panel meter to the fairing while I worked out a way to mount it. It fell off and shorted out on the fork, blowing the ignition fuse. I really appreciated Suzuki putting a spare fuse in the fuse box at that point.
post #10 of 11 Old 10-10-2013, 05:51 PM
oink's Avatar
I assume you've double checked the polarity.
oink is offline
