Complete Headlight failure; point me in the right direction please - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 13 Old 10-08-2013, 11:03 AM Thread Starter
BSK
BSK's Avatar
Question Complete Headlight failure; point me in the right direction please
Guys,
the other day I noticed that my headlights would randomly flicker and turn off especially when making Left turns. Well, yesterday the entire headlight stopped working.
I usually ride with my highbeams on all the time so the blue LED stopped working or was flickering prior to complete failure.
Having had this issue only during left turns makes me wonder if there is a loose connection somewhere. I looked but didnt see anything loose.
Any insights?
Stephan
DL650AL02 -> Barkbuster handguards, 12V outlet, Lee Whitehurst luggage racks, JCWhitney Topcase, 3M reflective tape, P3 lights, 52w LED fogs, forkbrace, Puig 5895h windshield... more to come!
Failures:
Chain and sprockets worn at 9100 miles, recommended to be replaced despite every 500 mile adjustment and lube =(
Entire wiring harness replaced at 9233miles by SEP after headlight failure
Rear shock busted at 9727miles
Bad burned oil smell since 9500miles found to be disconnected drain tube from airfilter housing
2nd chain done at 21.6k
BSK is offline
post #2 of 13 Old 10-08-2013, 11:10 AM
lordneeko's Avatar
https://www.stromtrooper.com/informat...blems-not.html
2006 Vstrom 650
1999 Triumph Trophy 1200
2012 Vstrom 650 (current)
lordneeko is offline
post #3 of 13 Old 10-08-2013, 12:36 PM
madstrom's Avatar
Check the 2 large white connectors on the wiring harness on top of the back side of the radiator shroud. They have barbed connections to the shroud from the engine side of the harness. I wound up snipping the barbs off with a good set of side cutters so I could get better access. Flex/wiggle them and see if the lights come on or flicker. If they do then separate them and check for browned/burned pins. Can't recall the pin numbers but they are side by side on the end of the connectors. Either connector will affect the headlights. Chances are you will need to do the Eastern Beaver headlight relay installation. Google headlight problems on Stromtrooper and VRSI you will find numerous threads on this subject. I did the fix on my 06' WeeStrom and then moved it to my new to me 11' as a preventative measure based my experience on my 06'. I posted on this a few months ago.
Grey Wolfe will probably offer some advice on this subject if he sees it.
Originally Posted by BSK View Post
Guys,
Any insights?
madstrom is offline
post #4 of 13 Old 10-08-2013, 12:52 PM
The usual culprit is the starter button switch. Electrical | Black Lab Adventures is on a 2007 model but it's probably similar. The radiator shroud connectors and large connector(s) in the left fairing are also possibilities. So is the hi/lo switch on the left handlebar. The best way to locate the problem is to check the wires for power on both sides of each connection. Is it just the high beam that cuts out or is it both beams? The answer to that will indicate which wires need checking.
post #5 of 13 Old 11-05-2013, 07:36 PM Thread Starter
BSK
BSK's Avatar
Thumbs down
its both that actually stopped working. the only thing lit were the positioning lights.
took the bike to the dealer as I bought into the extended suzuki warranty with the zero deductable.
Dealership called me on Friday stating that they couldnt find anything wrong. I advised that I rode blacked out on the interstate on Monday and that there is something wrong. They kept the bike and I guess on Saturday they found the culprit: fried wiring harness.
We will see what the suzuki warranty team will say. I've had nothing but bad luck with this bike sadly so far.
Stephan
Failures:
BSK is offline
post #6 of 13 Old 12-05-2013, 08:29 AM Thread Starter
BSK
BSK's Avatar
so suzuki extended warranty pickedup the tab on replacing the entire wiring harness on the bike.
The bike is unmodified with the exception of p3 lights =(
Stephan
Failures:
BSK is offline
post #7 of 13 Old 12-05-2013, 11:36 AM
Rogue Reaper's Avatar
Sounds like the dealer if fixing a hundred dollar problem with a $2500 fix if they are replacing the entire harness.
I guess if your not qualified to find and fix you just replace everything.
Sent from Motorcycle.com App
'09 Wee, Orange. Uh, Er...White, No, Wait, ORANGE!
" I like my Motorcycle's Loud and my Firearms Quiet." -Me
Rogue Reaper is offline
post #8 of 13 Old 12-05-2013, 11:44 AM
I wonder what figure would be arrived at by totaling the price of individual parts, much less the labor involved in putting them together.
post #9 of 13 Old 12-05-2013, 07:08 PM
They've had his bike for a MONTH. I'm gonna assume they attempted to replace the switch.
2012 DL650 Adventure - Black
OEM Hand guards, OEM Heated grips, Stroma Center Stand and Shifter, SV Racing Frame and Swingarm sliders, Eastern Beaver power distribution, Skene Visibility Lights
Pele2048 is offline
post #10 of 13 Old 12-05-2013, 07:18 PM
Scott E. Bonds's Avatar
I seriously doubt it. Dealers typically do not try to save money on parts and many mechanics I met while wrenching for money were basically parts changers. Rogue Reaper is likely correct and my Vee did the same thing. Couple hours cleaning up the starter switch that controls the lights and it was fixed. No new parts required. No wiring harness. Just some diss-assembly work of the switch and clean up with a pencil eraser. Its been 2 years since I fixed mine and lights still worked last night.
It didn't take them a month either. I sat for a month until somebody got embarrassed at looking at it and they repaired it.
We have had a total of one wiring harness replaced on this forum that I am aware of. Randyo is a maniac who rides all winter long in the snow and the road salt got to his.
But, don't sweat it. Its fixed...hopefully. Assuming the switch was replaced also....which is not part of the wiring harness.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
