Caliper bolt shook loose and missing. Do I need anything besides a replacement bolt? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 10-04-2013, 02:26 PM Thread Starter
This morning I found that my rear caliper is missing a bolt.
I see from the following page that I need, minimally, a new part #69182-04F00 (".BOLT").
2012 Suzuki V-Strom (DL650A) REAR CALIPER | Babbitts Suzuki Parts House
I have likely been riding with that bolt missing for a number of days.
Questions:
* Might anything else have been damaged?
* Should I order anything besides a new bolt as per above?
* Where can I find, or what is, the torque spec for this bolt?
File Type: jpg jramstet_2012vstrom_missing_caliper_bolt_pic1.jpg (87.8 KB, 154 views)
File Type: jpg jramstet_2012vstrom_missing_caliper_bolt_pic2.jpg (86.9 KB, 152 views)
wump is offline
post #2 of 8 Old 10-04-2013, 03:27 PM
It should be all you need. The front prong of the pad is out of the keeper and will need to be put back in place. Use 19.5lb-ft
post #3 of 8 Old 10-04-2013, 04:49 PM
Kelly2012's Avatar
Your rotor looks fine- looks like everything stayed in track.
Kelly2012 is offline
post #4 of 8 Old 10-04-2013, 05:43 PM Thread Starter
In the following post it's claimed that 69182-04F00 can be replaced at Home Depot.
https://www.stromtrooper.com/826987-post16.html
Originally Posted by NewHere View Post
... 69182-04F00 seems to be a perfectly replaced by an 8x50mm bolt with *1.25mm* thread pitch...
Can anyone verify this?
Edit: Thanks for the responses, Kelly2012 and greywolf
wump is offline
post #5 of 8 Old 10-04-2013, 05:57 PM
It will fit physically. It's a hardened alloy steel bolt though. Most hardware stores don't carry them. A hardware store bolt will probably do for a few days until a proper bolt can be obtained.
post #6 of 8 Old 10-04-2013, 07:20 PM
wingnut11's Avatar
Need some of this
I don't think I saw it mentioned, so I'll tell you that you need to get some of this stuff.
Loctite Threadlocker Blue 242 from Loctite Adhesives
wingnut11 is offline
post #7 of 8 Old 04-30-2018, 01:43 PM
Borghi's Avatar
Just found that I have the same bolt missing on my 2014. Did the factory forget locktite??? I've never had the bolt out, so I know it isn't my fault.
Borghi is offline
post #8 of 8 Old 04-30-2018, 03:56 PM
Borghi's Avatar
I just got back from the local Fastenal store. They had the correct size in a hardened bolt. Total cost was $0.00. The guy said he was too busy to ring me out and said have a nice day! I did put locktite on the bolt.
Borghi is offline
