OEM Heated Grip Connector Not The Best Solution? Why? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-27-2013, 12:00 PM Thread Starter
DGrav's Avatar
I've read in a few places that the OEM heated grip connector is not the best way to hook up heated grips. But I have not found a description of why this is the case.
I installed Oxford a Heated Grips directly to the battery last week while I waited for my connector to arrive from Eastern Beaver.
They work great but I planned on hooking them in via the OEM connector so they'd be on a keyed circuit.
So why is the OEM heated grip connector not the best way to hookup heated grips?
Musician, backpacker, Mt. Biker, learning how to be a motorcyclist.
DGrav is offline
post #2 of 10 Old 09-27-2013, 01:01 PM
from what i know, the circuit turns off under certain RPM's.
2012 DL650A; daily commuter http://www.flickr.com/photos/[email protected]/sets/72157633330697107/
Sold: 2003 SV650: weekend canyon carver http://www.flickr.com/photos/[email protected]/sets/72157630515234266/
fragile_this_side_up is offline
post #3 of 10 Old 09-27-2013, 01:42 PM
Mr_McBride's Avatar
I'm curious to learn how it does that.
-rodney
2012 G-Strom - White
Mr_McBride is offline
post #4 of 10 Old 09-28-2013, 03:11 PM
I used the EB harness to power my Oxfords through the OEM switched plug. So far, so good.
Tee Bee is offline
post #5 of 10 Old 09-28-2013, 05:47 PM
NeverSatisfied's Avatar
Actually, the Oxford Heaterz are designed to shut themselves off below a certain voltage- although a bike running at idle (thus the low RPMs), may be below that threshold, and the grips would then shut off anyway.
I had a set of Heaterz on my (carburated) EX-500, and if the idle was set too low and/or the battery wasn't well charged, sometimes at at red lights or other stops, they would shut off. (Not sure if a fuel-injected bike is immune to this shut-down, just relating my experience.) I do like the feature, as it prevents the grips from totally draining your battery down to nothing if you forget to turn them off. But I prefer running them off a keyed circuit, rather than straight off the battery like I had to with the old Kawasaki. Which is why the heated grip connector/plug that Suzuki provides is so nice. No worries, and I'm still pleasantly surprised by all the nice little touches I've come across in the design of the V-Strom. And yes, Eastern Beaver for the win, plug 'n' play!
2012 DL650
2018 DR650
NeverSatisfied is offline
post #6 of 10 Old 09-28-2013, 06:05 PM
Same setup here and no problems at all after one year of usage.
racefan is offline
post #7 of 10 Old 09-28-2013, 11:02 PM
Thumbs up
+2 No problems after a year
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #8 of 10 Old 09-28-2013, 11:18 PM
My bike came with the OEM heated grips and they work just fine at any RPM.
Rob
'17 Triumph Tiger 800XCA
'17 Kawasaki Versys-X 300
'04 Triumph Sprint ST
'96 Suzuki DR650
RobG is offline
post #9 of 10 Old 09-29-2013, 06:39 AM
:mrgreen:suzuki electronics are not that smart - i dont think even BM does it- unless you know something we dont.
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #10 of 10 Old 09-29-2013, 08:28 AM
"Actually, the Oxford Heaterz are designed to shut themselves off below a certain voltage"
That may be true once the grips have drained the battery. Mine are connected directly to the battery and I've left them on and they do drain the battery after a while. I hate when that happens. I really need to get the plug wire and run a relay off the factory connector so the key will shut off the supply.
