Aventure side bags - 3kg limit? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-25-2013, 03:22 PM Thread Starter
exzachtly1's Avatar
Just picked up my 2012 Adventure on Monday, and something struck me as I was going over the bike - only a 3kg weight limit on the stock side bags? That's only about 6.6 pounds. Is that really accurate?? Or can you load them up a bit more than that? Just seems low, especially when you consider the option of tying additional items on top using the provided strap brackets.
2012 V-Strom 650 Adventure
1982 Suzuki GS650L
exzachtly1 is offline
post #2 of 11 Old 09-25-2013, 03:40 PM
Sagebrush's Avatar
Most bikes have the same little weight ratings, like 10 lbs in the top box etc. I don't think I've ever had a bag loaded that light.
I had a rear rack sticker that said 12 lbs, thats about what the GIVI 52 actually weighs...
Sagebrush is offline
post #3 of 11 Old 09-25-2013, 03:48 PM
MeefZah's Avatar
There is no way that can be right... but if you have a label indicating that, I guess it must be.
That'd be one label I'd be inclined to ignore.
My Givis, loaded for a trip, weigh in at 19 lbs non exhaust side and 15 lbs exhaust side, and that honestly seems light to me. Even they are rated at around 20 lbs ea., and they are less substantial than the ADV bags.
I'm sure you would be fine at quadruple the weight, easily.
MeefZah is offline
post #4 of 11 Old 09-25-2013, 03:55 PM
srpkcop's Avatar
I noticed the same when I took possession of my bike. I think the bags themselves can take more weight. The problem is with the rack. A welding cracked on a recent trip. I had it re-welded in a local shop instead of trying to go through the warranty process. Less time consuming and cheap @ 15$. This is what the bike looked like fully loaded with extra dry bags strapped on top of the side and top cases.
srpkcop is offline
post #5 of 11 Old 09-25-2013, 05:18 PM
nuke's Avatar
My two (suzuki oem aluminium) side cases weigh between 15 to 20 pounds loaded. I also have a top case but don't keep much up there on long trips. The frame may be stressed if the bike was taken off road with that weight, but there does not seem to be a problem for normal highway riding. Side cases are normally only on the bike for trips.
2012 DL650/EXP (fox orange)
nuke is offline
post #6 of 11 Old 09-25-2013, 05:29 PM
two_wheeled's Avatar
Is the sticker on the inside of the lid?
I saw the same sticker and asked the same question.
I believe that 3kg limit is for the lid, not for the case. There are plastic hinges on the lid, therefore it can't hold a lot of weight when it's open.
-Steve in Phx.
Current: 2011 DL650A, Honda XR650L
Lost Loves: 2003 Honda ST1300A, Kawasaki Concours ZG1000, Honda Shadow VT500C, Honda Nighthawk CB700SC, Kawasaki KLR600, Yamaha TT500, Honda XR75
two_wheeled is offline
post #7 of 11 Old 09-25-2013, 06:28 PM Thread Starter
exzachtly1's Avatar
Ahhh! Now I'd be much more inclined to believe that. Makes total sense. And yes that is the sticker I was referring to. So basically, don't use the open lid as a seat
I'll have to check my manual and see if it gives a weight limit on the bags.
1982 Suzuki GS650L
post #8 of 11 Old 09-25-2013, 06:34 PM
Givi's home Italian site used to list bag weight and load limit. The E52's weight and load limit were equal. You could carry one but you couldn't put anything in it. Lawyers write that stuff.
post #9 of 11 Old 09-25-2013, 06:38 PM Thread Starter
exzachtly1's Avatar
Yeah, I mean I'm not looking to fill them with bricks or something. I think it would be reasonable to expect them to handle 30 lbs or so.
1982 Suzuki GS650L
post #10 of 11 Old 09-25-2013, 07:37 PM
I concur. The subframe and bags are pretty durable. I'd be comfortable with 20 pounds in them. Less if I was off-road, more if I stuck to the highway. But if I was borrowing YOUR bike, I'd fill them with bricks and go off road. ha ha ha ha ha
-Steve in Phx.
