12 volt switchable source for CB radio. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-23-2013, 01:05 AM Thread Starter
I have a 2012 Vstrom 650.
I recently purchased a J&M CB, model #JMCB-2003K-DU/SL.
The directions say that the orange wire should be connected to a 12 volt switchable source.
Which source should I tap into? And where is it located?
I plan to use posi-tap connectors.
Thanks
Landuser is offline
post #2 of 4 Old 09-23-2013, 01:15 AM
two_wheeled's Avatar
This usually means it's time to add a fuse block. Yay, another accessory! :mrgreen: Search the forum for "fuse block".
Put the fuse block on a relay, triggered off the rear tail light. Then, plug the J&M into the fuse block.
I also have a J&M and am going to be doing the same install on my 2011 DL650 in the coming weeks, so I'll be interested in seeing if you hit any road blocks. Good luck!
-Steve in Phx.
Current: 2011 DL650A, Honda XR650L
Lost Loves: 2003 Honda ST1300A, Kawasaki Concours ZG1000, Honda Shadow VT500C, Honda Nighthawk CB700SC, Kawasaki KLR600, Yamaha TT500, Honda XR75
two_wheeled is offline
post #3 of 4 Old 09-23-2013, 01:52 AM
Your best bet is an orange wire with a green stripe. A common source is a wire to the rear brake switch. There is also one in the connector set inside the rubber cover in the left fairing.
post #4 of 4 Old 05-15-2014, 03:49 PM
J&M radio
Any pics of how you mounted the radio? My wife just got a Strom and I need to change over her radio, haven't really looked at mounting yet but I know the setup from her FZ6 won't work.
cmichigan is offline
