fork gaiters - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 09-21-2013, 12:32 PM Thread Starter
mrbreeze's Avatar
fork gaiters
dumb question
how do you install fork gaiters?
I've got the RS1952's recommended by Greywolf
2013 DL650 Adventure
mrbreeze is offline
post #2 of 15 Old 09-21-2013, 12:46 PM
You take the forks off. If you have a fork brace, cut the bottoms off at the pleat shown to let the wide part rest against the brace. Otherwise, the bottom goes around the fork leg. Top and bottom (if not cut) can be held in place by zip ties but they often are not needed. I had a brace allowing both forks to come off together. If being removed separately, be careful of the fender bolts. https://www.stromtrooper.com/dl650-20...r-warning.html
post #3 of 15 Old 09-21-2013, 01:49 PM
If the spring is removed and the front jacked up, can the upper tube of the fork leg be slipped down far enough past the lower triple tree to get the gaiter over it?
post #4 of 15 Old 09-21-2013, 01:56 PM
Not with the front wheel on in my experience. It would take a cross member and a pair of jacks. A center stand and a single jack won't do it. I have a table lift and open joists but still took off the front wheel. That done, I removed the front forks as a set with brace and fender in place.
post #5 of 15 Old 09-21-2013, 02:33 PM
chicago's Avatar
There is a neoprene version as well that uses velcro and wraps around the tubes. If you have a fork brace it needs to be lowered on the legs slightly to allow enough space to clamp the bottom of the covers on to the legs with gear clamps. There was a photo here where someone did just and I copied it. They need to be attached to the legs with a clamp where a brace has been installed or they tend to ride up on the tubes.
chicago is online now
post #6 of 15 Old 09-22-2013, 02:58 AM
GotaV2's Avatar
I have the neoprene ones and a fork brace.
I did what PeteW did and loosened the fork brace then put a strip of velcro at the front and back of the fork then tightened the fork brace back up in original position.
Then put the covers on they stick to the velcro and stay over the seals and haven't moved since putting them on.
I can post pics if you like will need to take some though.
Cheers Gotawee
2014 DL1000AL4-Glass Glacier White
OEM centre stand,chain guard,decals,SW-Motech,crashbars,pannier racks,brake,exhaust,master cylinder guards, footbase,ROX risers,Givi Hugger, Airflow, panniers,top box,PivotPgs,OmniC,Rad Guard,mirror extenders,3 Guardian Bells, Oxford HG,Tutoro, Zumo 590, PC8,Crees, G2,Grip puppies,helmet hook,SitnFly,2xBC tank bag & ring,Ventura HP,FP lowering kit,SPOT,Backoff,2 Tool Tubes,Sena 10s,Contour,Hwy pegs, 2 Aux plugs,MJM seat,levers,Barrett Exhaust,Stebal Horn,Personalised Rim tape,PP & Holder, Barkbusters & Led,smiley face
2012 DL650AL2-Pearl Mirage White "Sparkles" 2011-2014
GotaV2 is offline
post #7 of 15 Old 09-23-2013, 07:55 AM
Hi Gotawee,
I'd like to see some pictures please. I'm taking my forks off to change fluid and put in Intiminators and would like to put these on at the same time. I have a fork brace to add too.
UlyBeeWee is offline
post #8 of 15 Old 09-23-2013, 04:39 PM
jrnyer's Avatar
Chers Gotawee
jrnyer is offline
post #9 of 15 Old 09-23-2013, 05:41 PM
blaustrom's Avatar
wrap around neoprene boots
That's what I have. No need to take the fork legs out. You can put them on and remove them any time:
NOJ Motorcycle Fork Guards Review - YouTube
Can't remember where I got them.
Good tip to clamp some Velcro under the fork clamp to hold them in placed since one of mine wants to ride up. I will try that, that should solve the problem.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #10 of 15 Old 09-23-2013, 07:47 PM
stoked steve's Avatar
Thanks to this thread, I remembered I had a pair of the neoprene/velcro gaiters from my old bike and I just found them, still in good shape after 7+ years.
They did a great job on the other bike, never had any seal issues. I couldn't fit them on with the fork brace, but now I get the velcro under the brace idea and will try that.
I like that you can easily remove them and wash them, when you see the crud they catch, you'll be glad that stuff's not on your tubes.
Long live the fork seals!
'12 DL650A VStrom
stoked steve is offline
Tags
fork , forks , gaiters , rs1952
