Spark plugs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 09-16-2013, 10:33 PM Thread Starter
Spark plugs
So today I pulled off my tank thanks to the great sticky here - I changed out my air filter and pulled my rear spark plugs to change. Then I got the wires off and pulled the plugs the little cap stayed inside the rubber wire cover. I just took the one off the new plug before seating it and it seems to fire fine.
Is this a problem though?
I was surprised to see the plugs were iridium, so I can't figure out for the life of me why they have a 12000km service interval! They had some corrosion and carbon build up but gapped okay so I'm not too worried about replacing the front plugs which seems more of a hassle.
Ploughjockey is offline
post #2 of 21 Old 09-16-2013, 10:53 PM
The interval is a recommendation, does not necessarily mean it needs to be done.
post #3 of 21 Old 09-16-2013, 11:47 PM
Dark Angel's Avatar
Unless the engine is REALLY hard on plugs, and I really doubt it, iridium plugs are usually good for seventy five thousand Ks or thereabouts. They might wear out sooner if you flog the engine, use crap fuel and generally abuse the bike ... but I can't see them going south in 12,000KMs.
Dark Angel is offline
post #4 of 21 Old 09-17-2013, 10:28 AM
I wouldn't think 12000 kms would be enough to affect any plug let alone an Iridium. I still think in miles so that equates to about 7500 miles. I'll have to check my manual to confirm what you said as I find that much too soon.
I think a more realistic time to change them would be when the valve adjust check/adjustment is done around the 24000 Km mark.
cycleman is offline
post #5 of 21 Old 09-17-2013, 05:46 PM
fortp's Avatar
I have 42000 km and i consider it half of their life.
fortp is offline
post #6 of 21 Old 09-18-2013, 12:48 AM
Kelly2012's Avatar
Iridium is better than platinum, but a lot less of it is used. The smaller center electrode is less durable than platinum- the sharp edge around the periphery is rounded off faster. It's the sharp edge that is the magic, and you're not likely to notice much of a gap change, depending on the construction of the outer electrode.
The recommended change interval does seem overly conservative for even 0.4mm electrodes, but I don't think expecting 75,000 miles is a reasonable expectation. The recommended interval may have to do with emissions regs requiring optimum lean starts and a lean idle. I'll inspect my plugs at the first valve check and change them at 30,000 regardless of how they look, unless I notice harder starts or missing at high throttle and lower RPMs.
Kelly2012 is offline
post #7 of 21 Old 09-18-2013, 04:01 AM
Dark Angel's Avatar
I said 75,000 Kilometres, not miles. That's a bit under 47,000 miles. I also said it would depend on the exact conditions the engine was running under.
post #8 of 21 Old 09-18-2013, 11:39 AM
Kelly2012's Avatar
Sorry Dark Angel, I just picked 75,000 miles at random not referring to your post.
post #9 of 21 Old 09-18-2013, 07:16 PM
I checked the manual and the Suzuki recommended maintenance service sheet and yes they recommend them to be changed at 12000 KM or every 24 months. Seems a little short to me but will watch the performance aspect and see what issues start to develop.
I'll probably just look at this one as a yearly maintenance item, like bleeding brakes, lubing cables etc and do it myself during the winter months.
cycleman is offline
post #10 of 21 Old 09-18-2013, 07:35 PM
Dark Angel's Avatar
No problem.
12,000KM is a ridiculously short interval for iridium plugs imho. For regular plugs, fine, for iridium, no. My old GT550 used regular plugs and only needed refreshing at about 20,000KM intervals IF I'd been giving it a hard time ... which I usually did but even then it didn't make much difference if any (phantom butt-dyno effect). The plugs always looked fine and the gaps would check just fine as well. The also only cost about $3.50AUD each so it was no big thing.
I wouldn't be surprised if the change interval was set with regular plugs and then iridium was substituted to help pass emissions testing.
