Skid plate for use with Yoshimura R77 exhaust? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 22 Old 09-16-2013, 01:27 PM Thread Starter
BMiracleTX's Avatar
So, today I finally received my TouraTech skid plate (after shiping it half way around the world!). I went to mount it up and the rear bracket won't mount. The Yoshimura midpipe extends down about 1/4-1/2" more than the OEM preventing the bolt holes from lining up. The rear bracket mounts to the exhaust hanger boly on the right side, and the front kickstand bolt on the left.
So, does anyone know if there is a skid plate out there that will fit with the Yoshimura exhaust?
2012 DL650A Adventure, Yoshimura R-77 3/4 exhaust, Sargent World Sport Performance Plus seat, ProTaper SE Raptor bars, SW-Motech 25mm risers, ProGrip Grips, Suzuki handguards, Tuono mirrors, Givi skid plate, Adventure Tech fork brace, GPS mount, peg lowering kit, auxiliary power shelf, SW-Motech convertible foot pegs, SW-Motech extended shift lever, SVRacing frame sliders, Garmin Zumo 660, MRA Xcreen, Michelin Pilot Road 3 Trails, Eastern Beaver headlight relay, Coocase V37
Currently in the United Kingdom and looking for great rides. PM if you have suggestions.
BMiracleTX is offline
post #2 of 22 Old 09-16-2013, 03:35 PM
mattski1's Avatar
My Enduro Guardian skid plate's rear bracket mounts exactly the same way and this is the exact situation I'm wary of. Perhaps you could give us the dimensions of the Touratech rear bracket and we'll compare notes to see what brackets might offer enough room? I'm very willing to contribute the EG info.
2012 DL650A Adv.
mattski1 is offline
post #3 of 22 Old 09-16-2013, 04:14 PM Thread Starter
BMiracleTX's Avatar
I have emailed Yann to ask him if he know if his plate wil work with the Yoshi.
For the Touratech rear mount, the measurement from the center of the side mounting holes to the top of the bracket (top being the part that would contact the exhaust which is actually the right screw that comes up through the plate is approx 2 inches.
post #4 of 22 Old 09-16-2013, 05:42 PM
Banned
You could look at the Givi one. I have it mounted with an Akrapovic and have no mounting issues.
RP3101 Alloy Bash Plate | A Pair of Stroms
zedex9r is offline
post #5 of 22 Old 09-17-2013, 02:15 AM Thread Starter
BMiracleTX's Avatar
Well, so far I have read that the Givi will work. I know the Touratech won't work. I emailed Yann about the Enduro Guardian plate and he said that it won't work either. Amyone know about the SW Motech?
Dang... sweet exhaust... now it looks like only the Givi plate will work. Does anyone know how the rear of the SW Motech mounts?
post #6 of 22 Old 09-17-2013, 11:53 AM
The rear bracket on the motech hangs from the exhaust hanger on the right and the kickstand bolts on the left side. There is just barely enough clearance for the stock exhaust. So if the yoshi hangs any lower it won't clear. Dang, I was interested in this exhaust. But I'll let somebody else be the guinea pig.
Surely the developer of this exhaust knows what will fit? If its incompatible with everything, or they dont know, then they really screwed up and need to start over. Al
ALinUTAH is offline
post #7 of 22 Old 09-17-2013, 12:15 PM Thread Starter
BMiracleTX's Avatar
Well guys, thanks for the info. Looks like the only one that will work is the Givi since it does not go back that far and use those mounting points.
post #8 of 22 Old 09-17-2013, 12:48 PM
Have you looked at "WELD86" skidplates......?? Or, the Hyde Racing Plastic plate. I'm not opening up a skidplate debate here on which one is better, just saying those two plates "may fit" with the Yoshi Exhaust installed. I believe that was the original question?
www.easternvstromrally.com
mark444 is offline
post #9 of 22 Old 09-17-2013, 02:44 PM
So the only bash plate that works with the yoshi is the one that leaves the pipe exposed. That defeats the purpose of a bash plate. -al
ALinUTAH is offline
post #10 of 22 Old 09-17-2013, 02:53 PM Thread Starter
BMiracleTX's Avatar
I guess it depends on how much you "bash" your bike. I don't... my 'Strom is limited to roads... whether that be paved, dirt, or gravel. I don't intend to be out bouncing it over rocky trails. i just want protection for the header and oil filter.
