JPR Levers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 09-15-2013, 04:04 PM Thread Starter
Toytech's Avatar
JPR Levers
Greetings,
I am looking to replace the stock levers (brake and clutch). I have read on this forum that most just don't work without modifying them. I searched looking for alternatives here. Anybody with good results? I found JPR Levers but they could not confirm if they would fit a Glee.
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #2 of 13 Old 09-15-2013, 04:22 PM
stoked steve's Avatar
I think the levers are a very common type and there are tons of aftermarket ones that will fit without modification.
I found some inexpensive ones on the site that shall not be named for about $55. They came in many colors and they can be adjusted in length and reach. They also fold up if impacted instead of breaking.
If you have the orange, don't get the orange levers, get the black, the orange is very reddish... I wish I had gotten the black or silver. (that's a rubber grip cover slid over the lever, not included).
'12 DL650A VStrom
stoked steve is offline
post #3 of 13 Old 09-15-2013, 08:47 PM
mattski1's Avatar
I bought some red "shorty" levers from MCMOTOPARTS off of ebay and have been very happy with the purchase. I didn't bother with their folding levers as I purchased shorties, but both are full adjustable, true to color and fit my 2012 Glee perfectly right out of the box. I might also add that while they shipped from China, the shipping was very quick. I think I had my levers within 4-5 business days.
2012 DL650A Adv.
mattski1 is offline
post #4 of 13 Old 09-15-2013, 09:09 PM
I want to do some levers too.
2014 BMW F800gs
2011 TW200
2012 DL650 SOLD
2007 DL650a SOLD
stephenmarklay is offline
post #5 of 13 Old 09-16-2013, 10:50 AM Thread Starter
Toytech's Avatar
Mr. Stoked,
There were no issues mounting them to the bike? Some of the levers bottom out on the grips at the curve. Some I have seen don't work with the factory hand guards. If you do not want to bring up the brand name PM me.
The orange is orange in the schematic pic and the on bike color sure is red looking. Thats a shame because I did want orange for my orange Glee.
Toytech is offline
post #6 of 13 Old 09-17-2013, 05:56 PM
Just replied to your PM, sorry, didn't see this post.
I did not have to modify a thing. They swapped right out. They do not touch the grips, I have them set for the closest reach on the clutch and it almost touches the grip at full grab, but then further out the higher in the number settings you go. The brake lever I have set at 2 and it is nowhere near the grip.
My only minor complaint is they are a little sloppy in the vertical deflection, but I also thought the OEM's were sloppy that way too, so no worse. I've thought about adding a small washer or two to reduce some of the play, of course not enough to restrict movement.
When I said the "site that shall not be mentioned" I was referring to EBay tongue in cheek.
Search for (brake lever foldable dl650)
'12 DL650A VStrom
post #7 of 13 Old 09-18-2013, 10:46 AM
njbill's Avatar
On that same site, item number 230790010984 claims to fit 2011-2012 Vstrom 650. I thought the levers from 2012 were different than 2011. Is that correct?
njbill is offline
post #8 of 13 Old 09-18-2013, 05:37 PM
I could be mistaken, but I think they are the same. Someone please correct me if I am incorrect.
The ones I got showed them fitting just about every Suzuki ever made and it would make sense to keep using the same levers on the new model unless there was some major design change.
'12 DL650A VStrom
post #9 of 13 Old 09-18-2013, 06:07 PM
The part numbers are different in the Suzuki fiche. That doesn't mean they won't fit.
post #10 of 13 Old 09-18-2013, 09:42 PM
njbill's Avatar
Thanks... I think I will give them a shot. How difficult could it be to return levers purchased on eBay and sent from China.
njbill is offline
