Coocase V37 brake light wiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 09-07-2013, 10:41 PM Thread Starter
I am a complete amateur at this, so I thought I better ask for input (already managed to burn out one fuse in my noob-ness).
I have a V37 Coocase with brake lights. The wiring kit for the case has a red, black and yellow wire. According to the diagram, red=positive, black=negative and yellow is supposed to go the running and/or brake light wire.
http://static.twisted-throttle.net/m...00011-1_v4.pdf
I also have the Eastern Beaver VStrom Brake/Tail/Signal Adapter, Version 2.
VStrom EB Harness V2
I read that if I'm not using brake light modulators with the EB V2 harness, I need to connect the red and purple wires of the harness together.
Could someone give me input as to how I should be connecting the red,black and yellow wires from the coocase to the EB V2 harness?
Dominik78 is offline
post #2 of 2 Old 09-17-2013, 12:49 AM
Maybe I'm a little late. I'm no pro, but having been wiring some lights up to my Vee using the version 1 adapter today, I'll try and help.
I'm getting some info from here:
Extras
I'm also going to make the assumption that the V-strom is of the Non-CANbus variety, so the diagram is at the bottom of the PDF you linked. Those instructions appear to be pretty confusing, and somewhat vague, so I'm going to do my best using the that diagram to what I know the EB adapter wires to be.
The Vstrom's ground wires all go to the negative battery terminal, so the black wire of the Coocase plate should go to the black wire of the Eastern Beaver adapter.
It appears the white (tail) and red (brake) wires of the adapter should both connect to the yellow wire of the plate.
So I suppose you should connect the red wire to the positive battery terminal, according to those instructions... hopefully the wire is long enough, but it should be easy to route it next to the under-seat tray.
If you've got the V2 adapter, you should connect the purple to the red and white as well.
The blue and yellow wires in the adapter are for turn signals, just wrap the ends in tape so they don't short to anything.
Hopefully that was helpful, but that's the best that I think that I can do.
Good luck!
brokeagain is offline
