Headlight wiring color codes needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-03-2013, 10:44 AM Thread Starter
Shag's Avatar
Hi all. I'm trying to install a Flash2Pass garage-door-opener on my '13 V-Strom 650. I see 3 wires leading to each headlight bulb. I'm guessing one is ground, one is low-beam, one is high-beam. I need to know which wire is ground and which is for high-beam by color. If you look closely at the picture below you can see a drop of blood on one of the wires. I had my finger under the wire supporting it as I tried to poke the wire with a voltage tester. I slipped and... took the picture and came inside to ask for help. :mrgreen: Thank you in advance for input.
2013 V-Strom 650
F*ck the brakes.
IBA# 38957
FredBGG does not approve of my riding.
Shag is offline
post #2 of 3 Old 09-03-2013, 01:24 PM
Left to right as they come out of the harness, B/W ground, Y high, B/Bl low.
post #3 of 3 Old 09-03-2013, 05:23 PM Thread Starter
Shag's Avatar
Thank you, Mr Wolf.
2013 V-Strom 650
F*ck the brakes.
IBA# 38957
Shag is offline
