Proper Break In on New 2012 V-Strom 650 ABS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 52 Old 08-28-2013, 09:44 AM Thread Starter
I picked up my brand new 2012 V-Strom 650 ABS from the dealership yesterday and drove it 88 miles. I mostly kept the engine well under 7500 rpm, but once or twice I approached the red line during a strong acceleration. I was curious to see its performance under a variety of different conditions. It was only at night before bed that I opened the owner's manual, scrolled to the break in section, and read that a maximum of 5000 rpm was recommended for the first 500 miles. I'm feeling very nervous that I may have potentially caused damage to my brand new motor . On the 45 mile drive from my apartment to work today, I was EXTREMELY careful to keep the motor at or below 5000 rpm, and I will continue to do so until I reach the 500 mile marker, as instructed in the manual. However, I can't undo what I did yesterday. Do any of you think I should be worried based on the few times I pushed past the limit?
Stephen is offline
post #2 of 52 Old 08-28-2013, 09:59 AM
Don't worry about it. The engine was wrung out at the factory on a dynamometer before shipping. I'm convinced the manual procedure is about keeping a new rider safe rather than the engine.
post #3 of 52 Old 08-28-2013, 09:59 AM
Not to worry - you properly seated the rings, and now all will be well. These engines are pretty bulletproof. Just ride reasonably to the 500 mile mark, get the service done, and enjoy!
kback is offline
post #4 of 52 Old 08-28-2013, 10:07 AM
The biggest thing to help with breaking in an engine is varying the rpms. I wouldn't wring it's neck the first 500 miles bouncing it off the rev limiter, but it sure doesn't hurt to let her breathe a little either. :mrgreen:
cheapbastard is online now
post #5 of 52 Old 08-28-2013, 10:19 AM
Listen to Greywolf..........
post #6 of 52 Old 08-28-2013, 10:39 AM Thread Starter
You know--I was thinking just that. Today, on the drive to work, I had a pretty straight and level state highway to drive on. I started from a stationary position and proceeded to accelerate through all of the gears, shifting at exactly 5000 rpm, then holding 5000 rpm steady in 6th gear. It seemed a little coincidental that in sixth gear, at 5000 rpm, I was going exactly 70 mph (the max speed limit on the interstate here, which is basically the top speed limit you'll see anywhere). I feel much better already--even as a new member, I can tell from you're posts that you are very knowledgeable about these bikes.
Stephen is offline
post #7 of 52 Old 08-28-2013, 10:41 AM Thread Starter
Sounds like sound advice. I know I shouldn't have done it--I just couldn't resist for a moment
Stephen is offline
post #8 of 52 Old 08-28-2013, 10:41 AM
V-Tom's Avatar
Originally Posted by Stephen View Post
... I was going exactly 70 mph (the max speed limit on the interstate here, which is basically the top speed limit you'll see anywhere).
I was plesantly surprised to see 80 mph limits in Utah in 2011.
I hear that some places in the rest of the world have higher limits.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #9 of 52 Old 08-28-2013, 10:46 AM
RCinNC's Avatar
I don't advocate ignoring the owner's manual (far from it), but believe me, if engines were that delicate that they could be damaged by a momentary RPM increase beyond the recommended break in, the sides of the road would be littered with the corpses of exploded engines....
Don't worry...just ride it and have fun.
RCinNC is online now
post #10 of 52 Old 08-28-2013, 10:55 AM
85 mph on the Toll Road starting near San Antonio, Texas. 80 mph in rural areas of I-10.
70 mph is common on two lane backroads in Texas!
Back on topic: Your engine is just fine. If break-in procedure meant much, we would see owners with oil burning or other engine issues.
There are none of those with your new DL 650!
realshelby is offline
