GStrom Tank Removal & Air Filter Access Photo Guide - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 35Likes
post #11 of 158 Old 08-21-2013, 07:21 PM
Originally Posted by Uncle Fester View Post
I assume that would be the time to add the eastern beaver headlight relay kit.
Not really, I installed my kit with just the left side tank plastic removed.
medve is offline
post #12 of 158 Old 08-21-2013, 07:46 PM
stoked steve's Avatar
This is a great post, thanks for making it a sticky. I've been dreading the tank lift, but not so much when I have a visual reference to follow.
To date I've been able to wire in the Eastern Beaver headlight relay and a PC-8, that is running many things, without removing the tank. I've done it mostly by routing through the left side, under the tank and over the radiator, following a factory bundle. It takes a bit of patience and effort to fish some of the wires, but wasn't too hard.
Now the air filter..I guess I can't avoid that.
Thanks for the how to on how to!
'12 DL650A VStrom
stoked steve is offline
post #13 of 158 Old 08-27-2013, 05:23 PM
THANK YOU THANK YOU THANK YOU
bantam is offline
post #14 of 158 Old 09-02-2013, 07:22 PM
Thumbs up
I tackled this job today and found your pictures and description to be most helpful. The only thing that was tough for me was the fuel line disconnect. I couldn't do it bare handed but used a small vice grip to pinch the blue tabs.
I labeled all the fasteners and taped them to to a legal pad. Jeez, 26 fasteners to remove to clean the air filter. I added the wiring for a cigarette plug/switch/USB unit while I had the tank off.
2012 DL650 Adv,Trax boxes, GiviT480, Hepco Becker center stand, Enduro Guardian skidplate
Drgas is offline
post #15 of 158 Old 09-03-2013, 03:17 AM Thread Starter
Good job, and I agree this is a bit excessive to get to an air cleaner. this is not hard, and I think the plastic will hold up fine over time.
DSR650
Austinsailor likes this.
DualSport Rider 650
2012 DL650A-L2 ABS ADV
2003 KLR650
DSRider650 is offline
post #16 of 158 Old 09-10-2013, 08:55 PM
Bruski's Avatar
How low does the fuel need to be to avoid major spillage?
Bruski is offline
post #17 of 158 Old 09-10-2013, 09:28 PM
fortp's Avatar
The reason is not the spillage, but the weight. I dont remember any drop spilled, even if i left 1 or 2 gallon in it.
fortp is offline
post #18 of 158 Old 09-10-2013, 10:14 PM
Sconde's Avatar
I did the lift on a full tank with no spillage. But the tank was d&ng heavy and awkward to get off. I recommend waiting until you are on the emptier side.
'12 650 ADV in White: Oxford heated grips, 12v socket x2, BarkBuster Storms, Pivot Pegz, OEM Aluminum cases and top box, OEM crashbars,
Sconde is offline
post #19 of 158 Old 09-10-2013, 11:35 PM
Bruski's Avatar
Thanks for the responses. I was just a little wary as my ST1300 requires an empty upper tank
Bruski is offline
post #20 of 158 Old 09-11-2013, 12:01 AM Thread Starter
The cloth to catch any fuel spill is from the service manual. The pump itself did not appear to leak, but I did have a little fuel from the hose end drip out. I happened to have the tank at about half full, certainly less gas is preferred but this can be done with a full tank too.
DualSport Rider 650
2003 KLR650
