Windscreen and Buffeting 2012+ DL650 - Appendix 1 - Custom Deflectors - Page 17 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #161 of 169 Old 04-14-2017, 02:01 PM
Standard m5 thread, length - depending on your spacer thickness, I used 25mm, flange button head in stainless to keep it neat.
UKPhil is offline
post #162 of 169 Old 04-30-2017, 07:34 PM
GreyMotion's Avatar
A friend let me borrow his Augustus Deflectors. Wow! They do a remarkable job.
GreyMotion is offline
post #163 of 169 Old 04-30-2017, 10:10 PM
Glad to hear it GreyMotion!
Producer of Augustus Deflectors, the first production wind deflectors for the 2012+ DL650.
Check them out in the "Stromtrooper Inventors-Product Showcase" Forum
Mimo256 is offline
post #164 of 169 Old 04-30-2017, 10:44 PM
shauneal's Avatar
Originally Posted by Outbackwack View Post
My Augustus deflectors worked so well on my 2012 that I added them to my 2013 as well. My wife says she now has no buffeting at highway speeds anymore (but still hates the highway). VERY pleased with the results and they look cool too
How or where do I go to purchase Augustus deflectors?
shauneal is offline
post #165 of 169 Old 05-05-2017, 05:03 PM
GreyMotion's Avatar
Check out the Inventors Forum or PM Mimo256 for info on the deflectors.
post #166 of 169 Old 05-16-2017, 09:17 PM
shauneal's Avatar
Just tested the Augustus Deflectors, they really help. Between those and my givi screen, I am really enjoying longer trips much more.
shauneal is offline
post #167 of 169 Old 09-09-2017, 08:28 AM
PerazziMx14's Avatar
Wind Deflectors my way
After about 3 different variants I have settled on a final design. Attached is a template if you choose to try and roll your own......
1. Roughly cut out patterns
2. Spray one side of pattern with 3M super 77 aerosol glue
3. Apply pattern to Acrylic sheet (Note: leave protective static cling on Acrylic, apply pattern on top of protective coating)
4. Rough cut around template with a rotary tool like a Dremel
5. Carefully sand (I have a 1" upright belt sander) away material until you reach the template outline
6. Hand sand the edges and drill hole
7. Peel off template and protecting coating
8. Heat and bend mounting offset
9. Heat and bend concave radius
I used 1/8" Acrylic sheeting and a heat gun to form.
PerazziMx14 is offline
post #168 of 169 Old 03-19-2018, 01:52 PM
Finally fixed the buffeting and noise issues. I bought the V-Stream touring windscreen for my 2012 dl650a, which got rid of about 70% of buffeting and noise from the wind. I am able to see over the top by about 2". I saw a used MRA touring auxiliary screen on Ebay, won the bidding, and added it to the top of the V-Stream. That took care of the buffeting at the top of my helmet, adding a good 3-4" of calm air (I am 6'3"). Next, I bought on Ebay a couple of add-on windscreens/spoilers that are supposed to clamp onto the top of the existing Suzuki screen, but I added them to the lower sides of the V-Stream. They were about $20. a piece, and are adjustable. They won't work well on the stock windscreen as the clamp is very large and the screen has creases which distorts the view. I already had the black plastic side Augustus winglets and mirror extenders. I drove the 650 up to about 84 MPH with no issues, but it's a little more sensitive to wind gusts. I also have to look through the MRA screen, which has not been a big issue so far. You can adjust out most of the reflections, and the MRA is well made and sturdy.
Spoilers:
https://www.ebay.com/itm/302615538923
rambunkshuss is offline
post #169 of 169 Old 12-07-2018, 06:55 PM
zulu's Avatar
Deflectors + loose headlight screw...need help!!
Received the deflectors and installed the left one, no issues. But the right screw on the headlight was free and kept rotating (I had some insurance work done and looks like the dealer messed it up) so I had to force the screw out. And as seen in pics out came the washer and the nut too. dont even mention the damage I can live with it if I can install the deflector.
Now, if I try to put the nut and washer back, the nut wont fit in the whole inside the fairing.
The nut is M5 0.8. is that even right? maybe that was the reason the screw kept rotating?
Does anyone know what is wrong or how to fix it?
thks
Manni
zulu is offline
Tags
air flares , buffeting , glee , noise
