Aux Connector and Heated Grip Connector Location - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 91Likes
post #21 of 367 Old 05-27-2013, 03:17 AM
The aux connector doesn't supply enough power for heated grips. You'll blow the ignition fuse. Use the heated grip connector. Don't ground to the frame. It can cause corrosion with a combined steel and aluminum frame. Check the wiring diagram with the grips. The blue and white wires go to the switch. The red wire goes to the heated grip connector negative (black/white on the bike). The hot wire to the switch goes to the heated grip connector positive. (orange/green on the bike).
Do you know what connector is needed for the heated grip connector? I'm assuming it is not the aux one I mentioned in my previous post!
boismj03 is offline
post #22 of 367 Old 05-27-2013, 07:33 AM
Uh, the one in post #2 showing the heated grip connector. Use that connector for your heated grips.
gleeful and McRooster like this.
post #23 of 367 Old 05-27-2013, 09:26 AM Thread Starter
briguy's Avatar
You can buy a pigtail already made up from eastern beaver for the Heated grip connector or the aux connector. Easter beaver has a $20 min order.
Heated grip pigtail
Aux pigtail (he calls it Accesory Adapter)
gleeful likes this.
briguy is offline
post #24 of 367 Old 06-07-2013, 07:58 PM
Just bought & installed the same shelf, but w/o the voltmeter. Where did you plug in the sockets? One to the aux plug & other to the heated grip plug? I've found both thanks to your helpful pix in this thread.
I saw in another post that the heated grip plug is only hot when the ignition is on. How about the aux plug?
sctr199 is offline
post #25 of 367 Old 06-08-2013, 08:33 AM Thread Starter
briguy's Avatar
I used the aux plug for everything on my shelf. I just put two wires in each crimp terminal to run to the next item until I reached the last item to wire up which I just put one wire in that terminal.
The aux connector is only hot when the ignition is on.
gleeful likes this.
briguy is offline
post #26 of 367 Old 06-12-2013, 01:57 PM
Factory Heated Grips Pigtail P/N
Does anyone know the factory heated grips pigtail part number?
Thanks in advance...
"If there was any logic in this world, it would be men who ride side-saddle, not women."
[B]2012 DL650A[/B] w/ Givi Crash Bars + AF3101, Touratech Skid Plate, EB Headlight Relays, AdventureTech Mirror Ext + Peg Lowering Kit + Fork Brace, Signal Dynamics Back Off XP, Lowering Links, Handlebar Risers, G2 Ergonomics Handguards and Plastics, Omni-Cruise, Radiator Guard, Garage Door Opener, TomTom GPS Charging Port, Dan Vessel Soft Luggage Stand-Off, Nelson-Rigg CL850's
wlkjw is offline
post #27 of 367 Old 06-12-2013, 02:06 PM
There isn't a separate part. However, there are two sources that will fit. A Suzuki horn lead will plug into the heated grips connector. Part number 36852-06G00
Also An Eastern Beaver VStrom heated grip adapter from VStrom will plug right in to the OEM connector. There is a $20 minimum order there though.
post #28 of 367 Old 06-14-2013, 09:10 PM
Do you really need the headlight relay? surely Suzuki didn't leave something serious out on the '12 because of a few $.
medve is offline
post #29 of 367 Old 06-15-2013, 12:09 AM
https://www.stromtrooper.com/informat...blems-not.html
Do you feel lucky? The new bikes still don't have headlight relays.
post #30 of 367 Old 06-15-2013, 10:28 AM
Well that sux.
So I guess in my case I would need;
H4 Dual Headlight Relay Kit FUSEHOLDER BATTERY CONNECT<-- I guess due to warranty, this would be the best solution for me, don't really want to hard wire it so it can be removed if needed.
VStrom Factory Heated Grip to Fuse Panel Adapter
The aux connector is basically for a GPS or phone charger. It's light duty. The heated grip connector is probably good for 40W or so.
Yet on the EB site it says: The factory heated grip connector is not the best place to supply power to heated grips.
DL650 2012 - on Accessory Adapter On DL650 DIY Kit (3 terminals and 3 seals) if need later for GPS.
medve is offline
