Aux Connector and Heated Grip Connector Location - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 79Likes
post #11 of 364 Old 05-25-2013, 04:15 PM
The aux connector is basically for a GPS or phone charger. It's light duty. The heated grip connector is probably good for 40W or so.
post #12 of 364 Old 05-26-2013, 04:44 PM
Captain Farkle's Avatar
Wow thanks a ton! Will save a lot of time come fall.
2012 650 Vstrom Black - Givi E52 Maxia Trunk,Givi Quick Release PLR3101 Racks, Givi E21 Silver Side Cases, Admore LED Brake and turn signals, SW Motech Crash Guards, SW Motech Center Stand, SW Motech Steel Rear Rack, SW Motech Bar Risers, OEM lower Cowling, OEM lower Seat customized by Triple K Upolstery, OEM Hand Guards, Eastern Beaver PC8, Givi Airflow Windscreen, Aprilla Mirrors, Dan Vesel Highway Pegs and Back Rest, Oxford Sport Heated Grips, FendaExtenda, Sena 10C, CREE LED Headlight Kit,10w Cree LED Work Lights,INNOV Wifi Bullet Cam
Captain Farkle is offline
post #13 of 364 Old 05-26-2013, 05:46 PM
Shag's Avatar
That aux connector... what is that connector type called? I'm wondering what kind of connector I'd need in order to plug into that aux connector. Thanks in advance for the info.
2013 V-Strom 650
F*ck the brakes.
IBA# 38957
FredBGG does not approve of my riding.
Shag is offline
post #14 of 364 Old 05-26-2013, 06:03 PM
The connector is the 2P090wp-MT-Special B. VStrom also shown on SM-MT
Eccentric likes this.
post #15 of 364 Old 05-26-2013, 07:04 PM
Shag's Avatar
Wow, I appreciate the information and fast response. I wish they could have just used a connector like you find on a typical trickle charger instead. But I suppose if they did that then people would wish they'd used a 2P090wp-MT-Special B connector instead.
2013 V-Strom 650
F*ck the brakes.
IBA# 38957
Shag is offline
post #16 of 364 Old 05-26-2013, 07:12 PM
The typical connector you describe is an SAE connector. You aren't going to find one of those on a Japanese bike. You're more likely to find Japanese connectors on a Harley.
post #17 of 364 Old 05-26-2013, 07:16 PM
Shag's Avatar
I just sold a Harley a couple of months ago. A lot of the nuts/bolts that I worked with on that bike were metric. Wouldn't have surprised me to find some Japanese style connectors on that bike, too. :mrgreen:
2013 V-Strom 650
F*ck the brakes.
IBA# 38957
Shag is offline
post #18 of 364 Old 05-26-2013, 07:37 PM
According to what I've read, at least most Harleys use Japanese Showa forks and Japanese electrics.
post #19 of 364 Old 05-26-2013, 09:08 PM
wiring 2P090WP-MT-SPB connector
Ive ordered the conector
2P090WP-MT-SPB for my after market heated grips. They are the ones with a high/low setting with a small toggle switch.
I am lookin for advice on wiring the OEM
2P090WP-MT-SPB connector. Do you run both high and low wires into one side of the connector?
I wired my bike up, not knowing of the OEM location.
My heated grips have 3 wires for each grip heater:
high > blue
Low > white
Ground > red
I tied in the blue to blue, and the white to white, and then the ground red wire for both sides.
I tapped a headlight wire and grounded it to the frame. it works but is a bit goofy.
I would like to use the OEM connector but I am unsure of the wiring on the connector I ordered:
2P090WP-MT-SPB
Thanks
boismj03 is offline
post #20 of 364 Old 05-26-2013, 10:00 PM
The aux connector doesn't supply enough power for heated grips. You'll blow the ignition fuse. Use the heated grip connector. Don't ground to the frame. It can cause corrosion with a combined steel and aluminum frame. Check the wiring diagram with the grips. The blue and white wires go to the switch. The red wire goes to the heated grip connector negative (black/white on the bike). The hot wire to the switch goes to the heated grip connector positive. (orange/green on the bike).
