Who has a DL650 still running with over 200,000km/125,000miles - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 25Likes
post #1 of 32 Old 06-17-2011, 01:07 AM Thread Starter
MountainLagoon's Avatar
Hello,
Does anyone own a DL650 with over 200,000km/125,000miles and you are still using it as your regular ride?
If so what were your major breakdowns/replacements over the years and recommended parts to keep an eye on at high mileages?
I am curious how long it can last with proper maintenance..
My riding style/type is long haul cruising with pillion, usually riding in moutain areas, plus daily average condition dirt roads.
2010 DL650A - black
MountainLagoon is offline
post #2 of 32 Old 06-17-2011, 11:27 AM
There is at least one:
wera688's thread on vstrom.info is the place to look, I think I saw that he is nearer to 200k miles now ...
100,000 mile K3 DL1000 writeup
his is a 1k but its a good start
tpak is offline
post #3 of 32 Old 06-17-2011, 11:34 AM
Phinhead's Avatar
Our local Suzuki mechanic told me of a DL1000 that went over 100k that he serviced. He added this into his, "You are wasting my time and your money on this valve check" speech.
He acted offended that I paid him to check the valves. He literally treated it as an annoyance.
Phinhead is offline
post #4 of 32 Old 06-17-2011, 12:29 PM
larry0071's Avatar
At what interval did the Suzuki tech feel would be a safe and prudant time to check?
One of my best pals for 30+ years is the service manager at a Zuki/Kaw dealer and he told me not to bring the 08+ KLRs in for a valve check until 20-25K miles. He says that of the ones that even read the manual and care to bring the bikes back in (He says that most will never return for service or check valves unless a bike stops moving) out of every 10 they pull open to measure... about 1 of the 10 really needs bumped back up to the big side at about 15K miles. And he went on to say that typically that one of ten bike was still GTG but was just approching the low side of the range.
So like your mechanic, my buddy says that it is a waste of time at the super conservative recomended intervals and he says on a KLR to just monitor for anything odd like a hard start issue or anything out of the ordinary and then react to that.
He told me that a fellow that rides both a Strom he knows is over 60K miles and refuses to pay for a valve check.
Roll of the dice?.... I'm sure to some extent.
03 DL1000 -Jesse Oddyses, PCIII USB, Staintune Mufflers, WindStrom Touring, WindStrom Laminer, Progressive fork springs with Amsoil 5W, KN filters, Givi E450 trunk, Corbin Seat, Heated Grips, Motech Crash bars and skid plate and Highway pegs, Amsoil 10-40 in her belly.
09 KLR650
09 KLX250
07 Rhino 660
larry0071 is offline
post #5 of 32 Old 06-17-2011, 01:39 PM
randyo's Avatar
I took my SV650 out of service at 135,006
very reliable, started even well below freezing the moment I thumbed the starter (a lot more reliable than the primitive FI in V-stroms) got better fuel economy than when it was new, 100% dealer maintained following recommended schedule
started using oil regularly at about 130k, (from top line of sight glass to bottom line every tank of gas, smoked noticably on cold starts, accels to redline and on decels from near redline but otherwise not noticable)
had a problem with the compression test, 210 front, 90 rear, repeat test, 205 front, 210 rear, repeat, 210 front, 140 rear
it really did run good, my theory is that at running speeds, the valve sealed tight, at compression test cranking speeds it didn't
every single valve guide was worn beyond tolerance, one exaust in the rear was so worn, you could move it noticable with yer hand, pistons & cylinders were ok, good rings, tight bearings, cam chains were also stretched beyond tolerance and oil pump was weak
cost to rebuilt or even buy used + take care of original suspension was more than bike was worth, this was December 06, dealer offered me deal I couldn't refuse, 07 VEE for $7500 otd
The Sv is now a project parked semi permenently on my bike lift engine out and parts in crates waiting to be turned into a bobtail motard, I'm thinking of rebuilding the engine 1mm over, tune to improve low & mid, new fork,
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 32 Old 06-17-2011, 02:00 PM
"cost to rebuilt or even buy used + take care of original suspension was more than bike was worth"
Almost makes me start thinking it's a throw-away bike. Ride the heck out of it for 100,000+ miles, then sell it for whatever I can get and call it good.
At my usual 5,000 - 8,000 miles per year, that's going to take quite a while anyway. Interesting.
Cascade Wanderer is offline
post #7 of 32 Old 06-17-2011, 02:14 PM
What Kinda Bike Is That?
Black Lab's Avatar
I just turned 91,000 miles on my 2007 DL-650. Standard Suzuki 10w-40 oil, and I do my own valve checks when I feel like doing something to my bike.
No problems.
B.L.
madstrom likes this.
Black Lab is offline
post #8 of 32 Old 06-17-2011, 03:00 PM Thread Starter
Thanks for all replies,
The wera688 write up of his maintenance history was exactly what I was trying to find, even though its a 1000cc. I did try searching this topic for the 650cc but I couldnt find much, If anyone has a high milage well running 650 similar info would be appeciated.
Interesting that his 3 valve clearance checks within 100k miles were all in spec.
Perhaps I should have titled this thread "Whats the longest milage your strom has lasted and still runs well"
Normally I would consider a 650cc bike retired or spare parts at about 100,000miles/150,000km but this doesnt seem to be the case with the strom !
Personally I change oil and filters more regularly than the recommended intervals because my bike is usually loaded with a pillion or luggage, its maintenance I like to do even if considered unnessesary by some riders (not trying to start an oil thread)
Its good to see from these replies the SV / Strom motor will to live up to its bulletproof reputation, as well as the rest of the bike.
Hope to join the 100k club one day
Polarbear99 likes this.
2010 DL650A - black
post #9 of 32 Old 06-17-2011, 08:28 PM
My 650 has about 245000, goes great. Just about to go out and put up some more.
PS I posted a detailed report on this board at 200k
RowBust is offline
post #10 of 32 Old 06-18-2011, 12:15 PM
Phinhead's Avatar
Larry, I have 20k on the bike, it was in the middle specs, and two separate mechanics told me to come back at around 60k.
I don't pretend to be a mechanic, and I am not weighing in one side or the other, and I am sure this has been beat to death in these forums. However, I am not doing it again until then.
Phinhead is offline
