Starting Problem - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 12 Old 06-12-2016, 04:16 AM
had the same symptoms as Icrouse - with the detais above quickly tracked down to clutch switch - sorted in seconds .. Big thanks!
DarthV is offline
post #12 of 12 Old 04-14-2017, 02:29 PM
DLB
Originally Posted by lcrouse View Post
I have a 2006 Vstrom 650 with about 20,000 miles. It has an intermittent starting problem which I have been unable to figure out.
Normally the bike starts right up but every once in a while, when I turn on the key, the gauges come alive, headlight comes on and fuel pump spins up but when I pull in the clutch and push the starter button, the headlight dims but nothing else happens.
I have checked all the normal things -- clutch switch, kickstand switch and starter switch and they all seem to be functioning normally. I have had this to the shop more than once but of course it never shows up there.
To date, I have replaced the battery and tip over switch but those haven't cured the problem. Anyone got any other ideas?
Thanks.
same thing for me except i get a click noise when hitting the start button any one know what is wrong with my bike?
DLB is offline
Tags
electrical , starter , starting
