Oil Change on 09 ABS dl650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 04-01-2010, 10:00 PM Thread Starter
I went to change the oil on my 09 vstrom and noticed the oil drain plug is behind the exhaust pipe. Am I looking at the right plug? I had an 08 vstrom and had now trouble changing the oil.
2009 DL650 ABS V-Strom
bneedles is offline
post #2 of 22 Old 04-01-2010, 10:09 PM
It's easily accessed. It's on the left side of the case at the bottom behind an inverted shark fin that is designed to protect it from getting hit by a rock. A 14mm wrench will fit it. It's #1 in the pic.
post #3 of 22 Old 04-01-2010, 10:12 PM
skyway_rider's Avatar
The oil drain plug is on the left side, bottom of crank case. It's right in line with the pedal to you gear shift lever.
Ummmm Doughnuts!
Warren
09 DL650 ABS (The Strominator)
Givi V-35's, SW Motech centerstand and engine guards, OEM Hand Guards, Sargent Seat, Vista Cruise, Givi screen with Madstad
skyway_rider is offline
post #4 of 22 Old 04-02-2010, 07:52 AM Thread Starter
ok, thanks guys, i guess i was looking at the wrong bolt
bneedles is offline
post #5 of 22 Old 04-02-2010, 08:31 AM
CanadianFZ6's Avatar
I had an 0'8 ABS and now an '09 ABS... The drain bolts are in the same place...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #6 of 22 Old 04-02-2010, 12:06 PM
Send a message via AIM to TedSki Send a message via Yahoo to TedSki
What you were looking at was probably the oil gallery drain nut. Its used to drain every drop of oil from the engine in preparation for disassembly. Leave that one there :thumbsup:
TedSki :: 2004 V-Strom 1000
TedSki is offline
post #7 of 22 Old 04-04-2010, 05:13 PM Thread Starter
I added 3 quarts, the oil shows low when off and over the full line when running, is this normal, it seems like last time I had to add slightly over 3 qts to get full. I don't remember the fluctuation before
bneedles is offline
post #8 of 22 Old 04-04-2010, 05:29 PM
3qts is slightly more than the full amount to be added when also replacing the filter. The sight glass is to be read with the bike held vertical and the wheels on level ground, not on the side or center stand. With the engine running, oil is pumped into the galleries and the level goes below the glass as a result. You may be seeing spray or mistaking no oil for all oil.
post #9 of 22 Old 04-04-2010, 11:58 PM Thread Starter
thanks, all is good then, just a wee bit overfull, should be fine...
bneedles is offline
post #10 of 22 Old 04-05-2010, 03:10 PM
I did my first oil change and checked the level after ~5 miles and I saw bubbles at the top of the oil leve in the sight glass. I didn't see any leaks so checked it again after 10 miles and still bubbles (but less of them).
I then checked after 100 miles and the bubbles were gone.
Any ideas...?
scharfg is offline
