Installing Protaper Raptor SE bar on 2008 DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 24 Old 11-13-2019, 06:33 PM Thread Starter
chikosneff's Avatar
Exclamation Installing Protaper Raptor SE bar on 2008 DL650
Hey guys after reading countless posts about handlebars I asked my mechanic to install a Protaper Raptor SE bar, from what I read it should go on with no modification to the bar clamps or wiring. I just got this image from my mechanic saying the the bar "raises up" before it can be properly clamped.
Is any of you rocking these? Did we order the wrong bar? This is what I asked him to order "ProTaper SE Handlebar - Raptor ATV Sport Bend - Jet Black 2146D JET BLACK" off amazon, not sure I can link the product here.
Thanks for helping!
chikosneff is offline
post #2 of 24 Old 11-13-2019, 06:43 PM Thread Starter
chikosneff's Avatar
Turns out Amazon has the wrong picture, the part I ordered is 02-5293, can these work on a vstrom or can anybody give me the correct part number for protaper bars? Thanks!
post #3 of 24 Old 11-13-2019, 11:19 PM
OCADVR's Avatar
This is what I installed on my 2007 Wee in 2016, also bought through Amazon.
Brand Protaper
Model Pro Taper Seven Eighths Handlebars - Standard 7/8
Item Weight 2 pounds
Product Dimensions 31 x 4.5 x 3.2 inches
California residents Click here for Proposition 65 warning
Item model number 025293
Manufacturer Part Number 025293
Jack
SoCal 92691
"I feel more like I do now than I did a while ago."
OCADVR is offline
post #4 of 24 Old 11-13-2019, 11:28 PM
Brockie's Avatar
I fitted the Pro Taper ATV MID 7/8ths bars with no issues. It appears that your bars do not have sufficient width across the handlebar clamps before curving upward. Thats unusual.
Brockie is offline
post #5 of 24 Old 11-13-2019, 11:36 PM
OCADVR's Avatar
Here are the Raptor bend SE bars on my 2007 with ROX Risers. I don't think the risers make any significant difference width of the mounts.
Edit: I take it back. The outer edges of the ROX Risers as I have them mounted are about 3/16" narrower than the OEM mounts.
Jack
SoCal 92691
OCADVR is offline
post #6 of 24 Old 11-14-2019, 06:35 PM Thread Starter
chikosneff's Avatar
Thanks! That explains it! I am sending the raptors back and installing atv mids or atv high!
Thanks again
post #7 of 24 Old 11-14-2019, 10:13 PM
Brockie's Avatar
My ATV MID's are about the same height as the OEM bars, but are wider and have less bend inwards therefore tending to be more comfortable with your elbows more outwards, dirt bike style. Had I thought more carefully I would have trimmed a half inch off both sides before installation. You will find that stock width is noticeably wider than OEM bars and still wider when narrowed a little.
Max in Montreal likes this.
Brockie is offline
post #8 of 24 Old 11-14-2019, 11:49 PM
Stalky Tracker's Avatar
I have had the ProTaper Seven Eighths (SE) ATV Highs for a number of years. I think they were about 32" wide, I cut a half inch off each end. Everything fits. I did loosen up some slack in the wiring as some were a tad snug.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #9 of 24 Old 11-15-2019, 03:59 AM
Another "ATV high SE" worked for me.
PeteW is offline
post #10 of 24 Old 11-15-2019, 11:15 AM
jokermtb's Avatar
do the stock bar end weights fit in the ends of these Protaper atv bars?
jokermtb is offline
