How do I detach the clutch cable at the clutch end? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 17 Old 11-10-2019, 11:19 PM Thread Starter
I'm putting tall handlebar risers and thus longer cables on my 2008 Wee. At the clutch end end of the cable, the cable is quite solidly attached to a metal assemblage that is part of the clutch throw-out mechanism, as the photo shows. The photo doesn't show well how it's held in there, but it's solid. Any tips on separating them? Do I just ram a small screwdriver in there and bend the metal out of the way, or am I being stupid and missing a truck?
File Type: jpg IMG_20191110_155233615_1573441941832.jpg (193.3 KB, 18 views)
Topher Eliot
2008 DL650A "Bucephalus"
tgeliot is offline
post #2 of 17 Old 11-11-2019, 12:08 AM
blaustrom's Avatar
Yours seems to be wedged in there pretty good. Normally you just need to push it down and then out back, when looked at as shown in your picture.
I think yours has been bend together more than necessary so you need to open it up a bit with a couple of screwdrivers and widen the center and the rear so the nipple is free to move.
V-Tom and NVDucati like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 17 Old 11-11-2019, 12:56 AM
Brockie's Avatar
Hold the cable (with pliers?) and push the nipple down into the empty space in the holder. You should then be able to slide the cable out sideways through a slot in one side of that holder. You should if possible avoid bending the holder/bracket.
Brockie is offline
post #4 of 17 Old 11-11-2019, 01:16 AM
V-Tom's Avatar
It's been a while since I've looked a clutch cable but to my untrained eye it looks as though the part of the cable above where it attaches to the clutch mechanism has solder or something on it that prevents it from being pushed down and released.
It looks to me like solder, I would put a soldering iron to that and see if it melts away and if so it should be easy to release the cable end.
..Tom
ps: bourbon time so some observations may not be accurate.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #5 of 17 Old 11-11-2019, 03:33 AM
Brockie's Avatar
Another thought. Does the new cable have that bracket already on it? and you have to remove a split pin from the peg?
I have never had to replace my cable.
Edit: No it does not. One side of that bracket must have a slit in it to slide the cable out once the nipple is pushed down.
Brockie is offline
post #6 of 17 Old 11-11-2019, 10:03 AM
blaustrom's Avatar
Originally Posted by V-Tom View Post
it looks as though the part of the cable above where it attaches to the clutch mechanism has solder or something on it ...
Too much bourbon. The nipple is cast "solder" cast onto the cable or its brass and soldered onto the cable. They all are like that.
The bracket has a tendency to tighten up purely by the forces of the cable nipple pulling on it. So just open it up gently and the nipple will come out.
V-Tom likes this.
Blau2 2014 DL1000A
post #7 of 17 Old 11-11-2019, 11:18 AM Thread Starter
I thank each of you for your replies. Unfortunately what's clear is that I was right, this photo doesn't show what's going on well enough. The dirt on the part obscures it a little too well. I'll clean it up and try again.
Topher Eliot
tgeliot is offline
post #8 of 17 Old 11-11-2019, 02:09 PM
Yeah, clean it up good. you might be surprised at what you find.
Cheers
RLBranson
RLBranson is offline
post #9 of 17 Old 11-11-2019, 09:38 PM
Brockie's Avatar
So I went to the garage and took off my countershaft cover. Here it is - dirt and all.
As in my first post you need to push the nipple into the bracket after which the cable will slide out the slot in the bracket.
I also wonder why you disassembled the actuator mechanism. Do you still have the ball bearings? I have added the second image to assist with reassembly.
Also note the actuator adjustment described here: https://www.stromtrooper.com/dl650-d...my-clutch.html
chicago likes this.
Brockie is offline
post #10 of 17 Old 11-11-2019, 09:44 PM
Fox
Fox's Avatar
Protip if you don't mind destroying the old cable... use a pair of strong wirecutters to cut the bent metal tube portion off the lever-end of the old cable. Use duct tape or electrical tape to join that end to the actuator-end of the new cable, and pull the whole thing through. No need to take the bike apart or worry about routing.
And the little metal tab keeping the current cable end just needs to be bent out of the way with a small flathead screwdriver, and it will slip out enough to clear the slot. No need to overthink it.
Fox is offline
