Brand new 650dl. Less than 100 miles. Won't start. Fuel pump engages. Solenoid engages. Just clicks. Lights fine. Battery at 12.3v. Engine light flashes 3x.
12.3V is a bit low for battery voltage. If your kill switch is on I would expect the "check" warning to be up. (perhaps early models don't have that) Solenoid clicks so your start button is working. You say new bike, 100km yet this is posted in 04 to 11 section. New to You? I would start with battery. Make sure connections to battery are tight. Loose connections will juice everything up but fail to provide enough to crank the starter. Charge up the battery. Should be just under 13V after charging up. You could jump the terminals on the starter solenoid to see if your starter works. At the same time check connections at solenoid and starter.
Brand new like as in a 2019 (100 miles)? From the write up in post #1 (fuel pump primes but solenoid just clicks), it sounds like either battery related, starter motor related (https://www.stromtrooper.com/maintenance-tech-products/165857-case-reluctant-starter.html) or maybe even clutch switch. The fact that solenoid engages shows the starter circuit via the clutch switch is complete but may be a weak / high resistance connection which fails under starting load conditions. You could try shorting out the starter relay to determine whether the starter turns or jump with a good battery. If you jump with another battery, take care that you don't damage the ECU.
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
