Brake cable ext / risers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Big Boy
post #1 of 8 Old 10-18-2019, 01:50 PM Thread Starter
thedrifter2010's Avatar
I would like to raise my bars up and back quite a bit so I was thinking of a 4-inch brake line extension with some risers similar to the ones pictured below.
Suggestions and comments welcome
Thanks
Tim "the drifter"
thedrifter2010 is offline
post #2 of 8 Old 10-18-2019, 02:01 PM
Big Boy's Avatar
Contact AdventureTech thru the forum.
Also, make sure that much rise won't interfere with electrical and throttle cables. You may run out of room!!! You need to be able to turn the bars lock to lock without pulling the cabling.
richlandrick likes this.
W. C. Fields
Big Boy is offline
post #3 of 8 Old 10-18-2019, 10:11 PM Thread Starter
Thanks Big Boy... I did contact Rick at Adventure Tech just waiting for a few more people to chime in with their experience before I go ahead and purchase a cable and some risers
Tim "the drifter"
post #4 of 8 Old 10-20-2019, 07:09 AM
om28's Avatar
Eastern Beaver has extensions for the wiring, with those risers you'll need one for each side.
2009 Wee Strom ABS (current)
1987 Harley FXR Low Rider Sport (current - with 206K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #5 of 8 Old 10-20-2019, 10:09 AM Thread Starter
So I guess what I'm really asking is how high can I go with risers before having to worry about left side cables
Tim "the drifter"
post #6 of 8 Old 10-20-2019, 10:28 AM Thread Starter
Never seen theses before are they suitable for the wee
File Type: png Screenshot_20191020-085317_1571578072150.png (728.4 KB, 10 views)
Tim "the drifter"
post #7 of 8 Old 10-20-2019, 10:37 AM
Best bet is to undo a few bolts and try your risers - or just hold the bars up where you want them if you have not purchased the risers. I made a dashboard for my '13 650 and found there was not a lot of play in the clutch and throttle cables. I had to unhook the wiring harness from a clip on the frame in order to get the free play. I've read here that risers will require 2" longer brake lines.
Longer clutch and throttle cables? Not sure of a source, but google should help. About 20 years ago I restored an old Guzzi, changing the carbs. This required some custom cables. After searching for a bit I found a company that sold cables, sleeves, ferrules, etc., I bought what I needed and made up my own cables. If I needed risers that's what I would do.
Someone posted that brake hoses are cheap from this company, but you can also get premade sets from AdventureTech.
Ratchet is offline
post #8 of 8 Old 10-20-2019, 10:45 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
I know a lot of people have gone 3" with our +2" kit. The number of people doing this and not reporting problems suggest that the throttle cables and clutch cable can accommodate the increase. Not sure how, maybe re-routing.
But I don't recall talking to anyone else about 4".
https://advrider.com/f/threads/longe...dl650.1073175/
https://www.stromtrooper.com/dl650a-...ox-risers.html
richlandrick is offline
