Fuel Pump disassembly question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By blaustrom
  • 1 Post By Fox
post #1 of 10 Old 10-18-2019, 12:56 PM Thread Starter
Seahawks's Avatar
Good day all
I have a 2006 dl650 with 68,000 km. Bought used in 2012 with 8,000 km.
Lately the fuel pump has been whining (not constantly) so I decided I would try to replace the fuel pump strainer.
When I pulled the pump I found what looks like some sort of sealant on the outside of the pump (red arrow), has anybody seen this before or do all the fuel pumps have this?
Seahawks is offline
post #2 of 10 Old 10-18-2019, 02:23 PM
V-Tom's Avatar
I don't think the fuel pump for a 2012 DL650 is the same as for 2006.
Don't have any other answer except perhaps you should Google "fuel filter bypass" as it worked brilliantly and inexpensively on my 2006 DL650.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #3 of 10 Old 10-18-2019, 02:42 PM
blaustrom's Avatar
Have you done the flow test? That will tell you if the main filter is blocked or not. A blocked filter can be the reason for the whining.
https://www.stromtrooper.com/dl650-d...t-results.html
Here is a picture from my old pump, looks similar:
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 10 Old 10-18-2019, 04:23 PM Thread Starter
Seahawks's Avatar
Thanks for the photo of your fuel pump, it looks like the portion I was wondering about is the same as yours.
I have done the fuel flow test and only got 120 ml so you are most likely correct that I will not be able to get away with just replacing the fuel strainer.
That being said, I have had no problems with the running of the bike and it pulls hard all the way to redline.
Seahawks is offline
post #5 of 10 Old 10-18-2019, 04:40 PM
blaustrom's Avatar
It will not pull hard if go up a hill with more load on the engine if the fuel flow is that low. Do the external fuel filter modification and be done with it. The strainer is cheap to replace if it's very gummed up or brittle.
V-Tom likes this.
Blau2 2014 DL1000A
post #6 of 10 Old 10-18-2019, 06:10 PM
My '04 pump shows the sealant around that upper end like yours. When mine started to whine I just ignored it. Not many miles later I regretted that in the pouring rain on Mount Evans. The bypass is a good move.
Bentwee is offline
post #7 of 10 Old 10-18-2019, 06:46 PM
Fox
Fox's Avatar
Many long-term strom owners have had to do the bypass. Eventually, power falls flat on its face at abrupt wide throttle openings. The upside is that it'll be right again for a LONG time, my replacement Wix 33095 filter has 90k carefree miles. I may replace it some day just for the hell of it.
Take care when sizing the fuel hoses, you want to avoid any tension at the fittings, contact with wires, etc. Be sure to buy FI-rated stuff.
5/16" fuel injection hose and clamps.
V-Tom likes this.
Fox is offline
post #8 of 10 Old 10-18-2019, 09:46 PM
V-Tom's Avatar
Initial signs of clogged fuel filter are reduced power at torque peak in higher gears. The fuel flow can't keep up with demand and the fuel injection runs out of fuel. This gets worse over time as the filter plugs more and spreads to lower rpms and higher rpms.
..Tom
My Opinion:
My Stroms:
V-Tom is offline
post #9 of 10 Old 10-19-2019, 05:19 AM
Fuel injection cleaner may help. Just an FYI.
I've had my pump start whining a few times now and a capfull of FI cleaner some k's and the whining goes away again. I do have a spare pump on the shelf but haven't needed to change it yet.
Just pointing out also that a complete replacement pump off eBay is in the $40 region and less stuffing around than doing the bypass. My OEM pump has 130,000k's and the intent is to just swap it out if it really griefs me.
There is some messing around with the fuel sensor but odds are that'll cause problems anyway just from touching the pump.
PeteW is online now
post #10 of 10 Old 10-19-2019, 12:49 PM Thread Starter
Seahawks's Avatar
Thanks for all the advice and info.
I already have the strainer and will get everything else I need for the bypass.
"Winter is coming" so I might as well keep busy.
Seahawks is offline
