How many miles - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Brockie
  • 1 Post By Ratchet
  • 1 Post By Stalky Tracker
post #1 of 6 Old 10-15-2019, 09:06 AM Thread Starter
Hendrik's Avatar
How many miles
I have a 09 DL 650 with 70k on the clock. It doesn't use oil and has been well car for. How many miles are these bikes good for and what can I expect to get before any major issues?
The older I get the faster I was
Hendrik is offline
post #2 of 6 Old 10-15-2019, 09:42 AM
Brockie's Avatar
Tom, a moderator here based in Ontario, has done 212,000km on his 2006 DL650 so far, and 203,000km on his 2016 DL1000.
Hopefully he will chime in with what, if any, his major maintenance has entailed.
https://www.stromtrooper.com/dl1000a...mile-club.html
DesertBike likes this.
Brockie is offline
post #3 of 6 Old 10-15-2019, 10:38 AM
My 04 Wee has 100+K miles and haven't had any engine issues. Hasn't had but one valve check at 80K miles.
Oil at 6K filter at 12K.
post #4 of 6 Old 10-15-2019, 11:14 AM
Modern engines last a long time, its all the other little pieces that need attention. If you do regular preventive maintenance, you should easily go 100k miles. Age is also a determining factor, because rubber parts (hoses, O-rings, etc.) don't last as long as metal ones. This is not a big deal if you do your own maintenance, but it can get expensive if you pay a dealer to do the work.
om28 likes this.
Ratchet is offline
post #5 of 6 Old 10-15-2019, 02:18 PM
Fox
Fox's Avatar
140k miles on mine so far and it has never left me stranded. Oil every 3,500 miles. Ridden year round and sits outside in Philadelphia, it has had a very hard life.
Non-routine maintenance:
- Wheel bearings
- Sprocket carrier bearing
- Shifter replaced (wore out)
- Oil cooler and lines replaced (started leaking)
- Fuel filter bypassed
- Starter rebuilt
- Cush drive rubber (multiple)
- Rear shock
The engine hasn't been apart since a valve clearance adjustment 120k ago. Probably worth re-checking.
These bikes are tough. Keep an eye on the oil level on long trips. Clean the electrical connections and switchgear with deoxit every once in a while.
Fox is offline
post #6 of 6 Old 10-15-2019, 08:26 PM
Stalky Tracker's Avatar
Wera688, on this forum, has gone 433,000+ miles on DL1000. I think there's a thread here somewhere that he details his maintenance.
Here's a pic of it from the 2016 Eastern V-Strom Rally.
YMMV
GlennTom likes this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
