‘05 Wee with alarming rattle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 11 Old 08-30-2019, 08:50 PM Thread Starter
AlanP's Avatar
My ‘05 WeeStrom has developed an alarming sound that I think is coming from the transmission when accelerating. In neutral or with the clutch pulled in, it doesn’t happen. I went to Google U, but I’m not finding anyone with the same issue.
If anyone could shed some light on this, I would GREATLY APPRECIATE IT. I’m currently at a campsite a few hours from home and I’m nervous to keep riding it for fear of causing additional damage.
Thanks,
AlanP
Trumansburg, NY
AlanP is offline
post #2 of 11 Old 08-30-2019, 09:41 PM
K9 Wee's Avatar
What does this alarming noise sound like? Whirring? Grinding? Scraping? Wheezing? Clunking? Clacking? Knocking?
Makes a huge difference! Can you get a phone video and post? Not trying to minimize what you are feeling, simply trying to get a sense for what you are hearing.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #3 of 11 Old 08-30-2019, 09:53 PM
I had the gear box on my sidecar BMW blow up a couple times. I still had a couple functional gears so I limped home in a gear that didn't make a lot of noise.
It may be possible with the Wee too.
Had the same on my solo R65LS BMW. I rode 150 miles home in 4th on the freeway. No noise, no worries!
post #4 of 11 Old 08-30-2019, 10:12 PM Thread Starter
AlanP's Avatar
It’s a rattle. Or a clack (is that a thing?). Imagine a couple bolts bouncing around in there. It happens on acceleration, so I don’t know that I could get a video of it. If it’s in neutral or I pull in the clutch, no noise. Starting to wonder if maybe it’s something to do with the throwout bearing.
Alan
AlanP is offline
post #5 of 11 Old 08-30-2019, 11:50 PM
blaustrom's Avatar
Are you sure its inside the transmission and not possibly the chain and sprockets?
Possibly the counter sprocket loose?
Is the rattle in all gears or gear or speed dependent?
Happening only on acceleration or also on deceleration?
Do you have givi crashbars? They sometimes rattle a lot.
Big B and Gert like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #6 of 11 Old 08-31-2019, 04:40 AM
K9 Wee's Avatar
I like Blastrom's direction...can you pull the front cover and inspect push rod and counter sprocket? Is it possible that you have a frozen link in the chain? That could make the noise you are describing under load and be quieter when freewheeling. Just a couple of thoughts. Hope you are able to figure out the issue!
Motor7 likes this.
2009 Orange DL650
Givi e22L Sidecases
Shad 33L Topcase
K9 Wee is offline
post #7 of 11 Old 08-31-2019, 04:16 PM
Sounds chain/sprockets related to me
DonOhio45813 likes this.
post #8 of 11 Old 09-01-2019, 11:44 AM
DonOhio45813's Avatar
T'was my first thought, and SO easy to check. Chain maintenance isn't fun, but so many ignore it until it starts getting noisey. It's a very risky thing to ignore!!
DonOhio45813 is offline
post #9 of 11 Old 09-01-2019, 02:23 PM Thread Starter
AlanP's Avatar
Okay, so a quick update. The good news - I added oil and it’s helped the situation. The bad news - I used a half quart in 200 miles yesterday. There is no smoke. There is no oily residue at the tailpipe. There is no visible oil leak and nothing on the ground.
Shit.
AlanP is offline
post #10 of 11 Old 09-02-2019, 04:15 AM
Gert's Avatar
If you travel at high speeds (7-8,000 rpm range) for long periods, I suggest that you read https://www.stromtrooper.com/dl650-d...ml#post5432955.
Gert is offline
