Do these seals need replacing? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Hilo Haole
post #1 of 8 Old 08-16-2019, 10:14 PM Thread Starter
ppanopoulos's Avatar
Here is a picture of my fork seal.
They seem a little dry rotted up top, is it time for just replace them? I have to do the steering bearings as well, so it might be easier since the forks are already coming off?
Thanks!
Pete
2006 V-Strom 650 RTW trip - www.atravelingteacher.com
Forum Thread: https://www.stromtrooper.com/stromtroopers-new-member-introductions/424339-traveling-world-my-dl650.html
ppanopoulos is offline
post #2 of 8 Old 08-16-2019, 10:26 PM
Hilo Haole's Avatar
That seal is actually a dust seal. The fork seal is below that item. They won’t get any better so if you’re going to have the front end apart...
MrF likes this.
Paul
2005 DL 1000
2008 ST 1300
Hilo Haole is offline
post #3 of 8 Old 08-16-2019, 10:34 PM Thread Starter
Originally Posted by Hilo Haole View Post
That seal is actually a dust seal. The fork seal is below that item. They wonít get any better so if youíre going to have the front end apart...
If there is zero leaking from the seals could I just replace the dust seals or should I just go for the whole thing?
Thanks again
post #4 of 8 Old 08-16-2019, 10:41 PM
Hilo Haole's Avatar
I don’t like to fix things that aren’t broken. If the oil seals are not leaking you are probably ok with just the dust seal replacement. On the other hand you have to factor in the age and mileage of the bike. Do you know the history of maintenance performed? Has the fork oil ever been changed?
Paul
2005 DL 1000
2008 ST 1300
post #5 of 8 Old 08-16-2019, 10:51 PM Thread Starter
I donít like to fix things that arenít broken. If the oil seals are not leaking you are probably ok with just the dust seal replacement. On the other hand you have to factor in the age and mileage of the bike. Do you know the history of maintenance performed? Has the fork oil ever been changed?
I don't have history of maintenance, to my knowledge the previous owner did not replace anything. The bike has just under 50k miles at this point
post #6 of 8 Old 08-16-2019, 10:55 PM
Hilo Haole's Avatar
Checking your profile shows the bike is an 06. Knowing that and your uncertainty of it's maintenance history, I would replace oil and dust seals along with a flush and new fork oil.
Paul
2005 DL 1000
2008 ST 1300
post #7 of 8 Old 08-16-2019, 11:00 PM Thread Starter
Thank you for your help!
Much appreciated
Pete
post #8 of 8 Old 08-16-2019, 11:12 PM
Hilo Haole's Avatar
No problem, that's what this forum is about.
Paul
2005 DL 1000
2008 ST 1300
