Ignition switch won't turn off! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 11 Old 08-15-2019, 04:23 PM Thread Starter
Hello! My 2005 650 did something really weird yesterday. I rode it to work, rode it mid day, all fine. When I left in the evening I turned the key on, then back off because I forgot something.....and the headlights and dash didn't turn off! Cycled the ignition switch several times, same result, started engine, same result - turning the ignition switch off didn't kill the engine, although the kill switch did, but the lights still stayed on. The key action felt normal. OK, I figured I'd ride it home and then disconnect the battery. But when I got home the ignition switch worked normally! And today, so far so good. So somehow, my ignition switch turned on and was not responsive to turning the key back off, but then riding time and maybe vibration fixed it, at least for now.
This is not the first time I've had weird behavior from the ignition switch, see the thread below if you're interested. After that I followed the instructions also linked below to take the switch apart. I didn't really find any anomalies, everything looked pretty normal in there. No cracked solder joints, loose conductive objects rolling around inside the switch, that kind of thing. I cleaned everything, greased it and put it back together. This is the first time it's acted up since.
So what the heck? Maybe the tab that clocks the key portion to the switch electrical portion is wearing out and coming undone occasionally? But again, it didn't look worn when I worked on it. Maybe it's time to bite the bullet and buy a new ignition switch. Anybody seen this behavior? Thanks!
My previous thread from 2016:
https://www.stromtrooper.com/dl650-d...t-key-etc.html
Reference thread for fixing ignition switch:
https://www.vstrom.info/Smf/index.ph...c,10907.0.html
GearheadS is offline
post #2 of 11 Old 08-15-2019, 09:03 PM
Brockie's Avatar
The contacts in the bottom of the switch are making contact when they shouldn't. Could moisture be involved?
Perhaps its worth a second disassembling a second time. As it is occasional, and the kill switch works is it a big problem?
Brockie is online now
post #3 of 11 Old 08-15-2019, 09:12 PM Thread Starter
Hi Brockie,
Yes, kill switch is fully functional for the engine, it leaves the lights on of course. And I packed my 10mm but driver, just in case I have to disconnect the battery 😉
Moisture is not involved. I'm in AZ, it's been a hot, dry week. It's only happened once so far since I reworked the ignition switch. In my previous weirdness 3 years ago, moisture did make it worse.
Sumthin is certainly bridging the contacts, whether in the switch or in the wiring somewhere, like if two wires have rubbed through. That seems very unlikely though.
post #4 of 11 Old 08-15-2019, 09:33 PM
Brockie's Avatar
If you do take it apart again I would carefully look at what might bridge the contacts. Bared wires would seem unlikely, but grasp and flex the loom to the switch with the ignition off to check.
Is this link any help? https://www.vstrom.info/Smf/index.ph...c,10907.0.html
Gert and GearheadS like this.
post #5 of 11 Old 08-19-2019, 06:54 PM Thread Starter
Yeah, that's the link I posted in the original post. I followed that procedure a couple years ago when I worked on this before, didn't find anything foreign in the switch. I was really expecting to find some loose metal in there.
post #6 of 11 Old 08-19-2019, 08:39 PM
This problem of the engine continuing to run is also happening to me. not consistently.
when I turn off the ignition, the engine would continue to run a second or two. but not all the time.
This only occurred after I installed the H4 Relay kit so scratching my head on this. I never use the kill switch when turning engine off.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #7 of 11 Old 08-19-2019, 09:25 PM Thread Starter
Huh, the PO of my bike installed a relay kit as well. How could that cause this though? Doesn't make sense.
post #8 of 11 Old 08-19-2019, 10:13 PM
Brockie's Avatar
That's a common denominator that should not be ignored. Depending on how often the fault occurs, could you not experiment by disconnecting the relay kit for a while?
Are any of your accessories at all connected to the OEM wiring? Even an earth?
post #9 of 11 Old 08-20-2019, 02:24 AM
Rolex's Avatar
This has been reported by others on hot days.
When the radiator cooling fan is running it can produce enough power to back feed into the ignition system to keep the motor running after the key has been shut off.
If the fan is not running when the key is turned off the bike will shutdown as normal.
Gert likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #10 of 11 Old 08-20-2019, 10:05 AM Thread Starter
Huh, the plot thickens. That's weird. This last time for me I had not been riding all day, but it was hot, sitting under a cover in the Tucson sun. But the fan was not running.
