Handlebar Wobble - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 26Likes
post #1 of 45 Old 08-09-2019, 12:10 PM Thread Starter
ppanopoulos's Avatar
Handlebar Wobble
Hey!
So since I bought the bike, I noticed if I let go of the handlebars they start to wobble pretty bad (both loaded or unloaded).
I checked the front bearings for play, and there is not play at all.
I checked the front tire for cupping, looks totally fine. I have since replaced the tire, and same thing.
I am looking to invest in some steering damper, because the weird thing is, if I am going into a turn with no bumps from a stop, no problem. But from a stop if I go into a turn and hit some uneven pavement or a bump, starts to wobble again.
I have seen people rant and rave about the Scotts Steering damper, and while I would prefer not to spend that much money, it seems to be a matter of safety at this point.
Any thoughts/comments on this?
Thanks!
2006 V-Strom 650 RTW trip - www.atravelingteacher.com
Forum Thread: https://www.stromtrooper.com/stromtroopers-new-member-introductions/424339-traveling-world-my-dl650.html
ppanopoulos is offline
post #2 of 45 Old 08-09-2019, 12:12 PM
Big Boy's Avatar
Check to see if the preload and all other settings are the same for each fork. If not setup the same, they could be the cause of your wobble.
W. C. Fields
Big Boy is offline
post #3 of 45 Old 08-09-2019, 12:16 PM Thread Starter
I notice the slots up top are not the same angle where I'm assuming I would adjust them. How can I tell which way to go on them/ which one is loaded more?
This could be the issue for sure
post #4 of 45 Old 08-09-2019, 12:20 PM
Big Boy's Avatar
Measure the height of each adjuster from the base. They should be the same height. Clockwise turns will increase the preload.
DesertBike likes this.
W. C. Fields
Big Boy is offline
post #5 of 45 Old 08-09-2019, 12:26 PM Thread Starter
I just measured them, .8 cm from base they are perfectly aligned.
thank you for telling me this!
Any other thoughts?
post #6 of 45 Old 08-09-2019, 12:28 PM
You say you checked the front bearings. do you mean front wheel bearings or steering bearings? the steering bearings should be snug enough that there is a noticable SLIGHT drag or preload on them.
RLBranson is online now
post #7 of 45 Old 08-09-2019, 12:43 PM
V-Tom's Avatar
If you are taking about a low speed waggle that immediately stops when you put your hands on the handlebar it is a well know issue on first gen DL650's
The only total fix seems to be roller bearings in the steering.
Things that can help are narrower profile front tires (ie Torrance Next instead of regular Torrance tires and other tires with narrower fronts. Tires worn flat are more likely to do it as are tires with lower pressure.
Things that don't help include a fork brace. These are wonderful devices but have no effect on this. I have no effect with steering damper so can't speak to them.
..Tom
Gert and DesertBike like this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #8 of 45 Old 08-09-2019, 12:51 PM
Big Boy's Avatar
This is the 2012 V1000 suspension adjustment instructions from the users manual.
ppanopoulos likes this.
W. C. Fields
Big Boy is offline
post #9 of 45 Old 08-09-2019, 02:43 PM Thread Starter
I checked this out and it seems pretty good, especially with the weight I'm going to keep them on the stiffer side, though not too stiff.
post #10 of 45 Old 08-09-2019, 02:44 PM Thread Starter
Steering bearings, let me do another check on if there is a slight drag on them
