Oil Top Off Volume Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 20 Old 08-05-2019, 07:19 PM Thread Starter
Hmm
Hmm's Avatar
Hello Team. I have searched all over for the answer to this question but can't seem to find one in the massive amount of oil posts on here.
I have a 2008 DL650. Does anybody know what volume to add to top off the oil from the lower sight glass line to the upper one? I know that I can add a bit, crank/run/check but I thought that I would ask. I definitely do not want to overfill. I would rather be a tiny bit lower than full than bit a tiny bit over.
Bill
I been down around Houston Texas where the sun shines most of the time.
2008 Wee current
2014 Spyder RT LTD current
Past - Yamaha 850, Honda Nighthawk 700, Honda GL1200, Yamaha FJ1200, Suzuki Bandit 1200, Honda GL1800
Hmm is offline
post #2 of 20 Old 08-05-2019, 09:28 PM
Don't run it, then check. The engine should be off for several minutes for most accurate check. Bike should be on level ground & straight up, at the balance point when you check.
Pour a few ounces in, give it a couple minutes to run into the sump/pan, then check.
Gert and Brockie like this.
2007 DL 650 with assorted upgrades
Solo is offline
post #3 of 20 Old 08-05-2019, 10:37 PM
callowrider's Avatar
Engine warm then off right?
2012 - V-Strom DL650A
callowrider is offline
post #4 of 20 Old 08-05-2019, 10:39 PM
V-Tom's Avatar
Makes no matter.
Main thing is that it is sitting for a while.
..Tom
Gert likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #5 of 20 Old 08-05-2019, 11:30 PM
The Guru of Stroms, GW, mentioned that on the center stand a full site glass was a full fill of oil.
I usually check mine before the ride for accuracy.
Stalky Tracker likes this.
post #6 of 20 Old 08-05-2019, 11:39 PM
nvr2old's Avatar
I found it took 12 oz. on my 650.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #7 of 20 Old 08-06-2019, 05:15 AM
Rolex's Avatar
I believe having a high oil level helps keep the stator cool and lengthens it's life.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 20 Old 08-06-2019, 07:13 AM
PerazziMx14's Avatar
Run the bike until properly warmed up. Come home put on center stand and get you a cold drink. After 5 minutes look at the sight glass and see where the oil level is. If it is at mid sight glass or above no need to add. If it below 1/2 way up the sight glass break out the oil jug and top it up. Drizzle oil into the filler hole until you reach the desired level and stop pouring. Let the oil settle for a few seconds then verify its still at the level you want. If good put the filler cap back on and your done. Or add a bit more oil as needed to get to the desired level.
DO NOT worry how much oil in ounces is from low to high. Since you dumping straight from the oil container and watching the level rise its sort of moot.
Motorpsychology likes this.
PerazziMx14 is offline
post #9 of 20 Old 08-06-2019, 10:54 AM
V-Tom's Avatar
Pretty sure he said that on the center-stand the reading was slightly optimistic so that if it was showing at the top line on the centerstand it was actually slightly below.
..Tom
Solo likes this.
My Opinion:
My Stroms:
V-Tom is offline
post #10 of 20 Old 08-06-2019, 11:08 AM
V-Tom's Avatar
Funny in 13 years of Strom ownership and 49 years of Motorvcycle ownership I have never heard of making sure the oil is warm before checking. For changing the oil yes, always. For checking it, never heard it. Did I miss something?
In 533,500+km / 331,500+ miles of total Strom Mileage I have never intentionally down so either and never had any issues.
This doesn't need to be over thought. Just check the oil level on the centerstand and if it is somewhere between half and full keep riding.
..Tom
dravnx likes this.
My Opinion:
My Stroms:
V-Tom is offline
