Which Service/Repair Manual to buy under $75? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 11 Old 07-20-2019, 08:08 PM Thread Starter
Question
Pretty simple, title says it all. The specific reason I need one is that a bolt fell out of my bodywork after picking the bike back up which was laid over in an attempt to retrieve my lost bar-end inner nut.
I have no idea what this bolt goes too, but it's about 4" long, has a flange/flat thingie on the head, is a 10mm bolt, and only has the last 1" or so threaded.
There's also a bolt missing from my lower triple clamp. Tried to fit this bolt in there, but it seems too long. Gonna try to find an empty hole tomorrow.
Does anyone have the part number for the lower triple clamp bolt in the meantime? I can order it at the same time as the manual.
Will edit in pics on the phone if I can, or else upload them in a reply.
File Type: jpg IMG_20190720_191121037_1563664969939.jpg (245.1 KB, 6 views)
File Type: jpg IMG_20190720_191130022_1563664981604.jpg (123.3 KB, 5 views)
File Type: jpg IMG_20190720_192940915_1563665431170.jpg (217.2 KB, 6 views)
2006 DL650
DrunkenHamster is offline
post #2 of 11 Old 07-20-2019, 08:22 PM
blaustrom's Avatar
Get the Suzuki factory service manual.
You can find any part number easy from any online OEM parts seller. They all have the OEM parts diagrams.
The bolt that fell out with short threaded section, I wonder if its broken off and the remainder of the bolt is still stuck wherever it belongs. Does the bolt end look normal and machined?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #3 of 11 Old 07-20-2019, 08:31 PM Thread Starter
Doesn't look broken off. I added pics to the original post.
2006 DL650
post #4 of 11 Old 07-20-2019, 08:34 PM
Jim L's Avatar
looks like the bolt that goes through the front of the gas tank
Jim L is offline
post #5 of 11 Old 07-20-2019, 08:44 PM
blaustrom's Avatar
Yes, agree. I bet your tank is not secured at the front. It uses a nylock nut if I remember right.
The bar end weight nut is behind an expandable rubber plug. Probably the same size as the tank bolt. If you use that or the proper bar end bolt, carefully thread it in about 2-3 turns, then push inwards, it will unstick the rubber and then you can pull it out.
Here is another procedure: https://www.vstrom.info/Smf/index.php?topic=10943.0
Hard miles likes this.
Blau2 2014 DL1000A
post #6 of 11 Old 07-20-2019, 09:12 PM Thread Starter
I'll get a new nylock then for the tank bolt. As far as the bar end thing, I already tried re-threading it and just ended up pushing the rubber and nut in more. Pulled the rubber out with a bent welding rod, but couldn't retrieve the nut. Pretty sure it's in the middle of my bars, now.
Also, my left hand controls housing is split open like it's missing bolts or something. Hasn't fallen off and doesn't seem like it will, but it does rotate easily. Definitely bitching out the bike shop tomorrow, assuming they're open. Sucks, too, I have a lot to do tomorrow and I just wanted to enjoy the damn weekend... :/
2006 DL650
post #7 of 11 Old 07-20-2019, 11:09 PM
blaustrom's Avatar
Look for a small magnet with a hole in it, attach to a wire and you will get the nut out.
Alternative attach a pvc hose to your vacuum crevice nozzle (needs some tape). That should also get the nut.
Blau2 2014 DL1000A
post #8 of 11 Old 07-20-2019, 11:10 PM
Brockie's Avatar
Here is an image of all the parts of the bar end weight. Parts #8 and #5 are rubber. The nut is usually embedded into the compression rubber and some people have resorted to compressed air from the other side to get it out. Otherwise a length of fuel or brake line to push the bits out. If you need to remove the throttle side it is easiest if you loosen the four handlebar mounting bolts and move the bars to the left. You can loosen the throttle side switch block and then have the cable clearance to slide the whole throttle assembly off the bar without needing to disassemble it.
There may be more bits still in there than you realise.
For the lower triple clamp bolt remove the same bolt from the other side and take it to the dealer or a parts shop to purchase another.
Brockie is offline
post #9 of 11 Old 07-20-2019, 11:54 PM
I think Brokie is right, my first thought. i got a factory manual from the forum for sale section and paid about $25.
notacop is online now
post #10 of 11 Old 07-21-2019, 01:48 AM Thread Starter
Part 9 is the missing part, I have the rest. As for the triple clamp bolt, well, the only way for me to get around is the bike, sooo... Looks like I'll be going to my local shop, instead? Or just ordering online after looking in the manual. Which I also need to order.
2006 DL650
Tags
bolt fell out , lower triple clamp , missing bolt , service manual
