Pvc pipe storage mod? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 27Likes
post #1 of 42 Unread 07-09-2019, 01:54 PM Thread Starter
1NHVStrom's Avatar
Hello, I am a longtime rider, new 2005 Vstrom 650 DL owner. I have seen a few Vstroms in the past with a PVC pipe storage setup on the left side, mounted to the Pannier brackets. I am thinking about doing this on my Vstrom, is this a common mod? Is there a common name for this mod? Does anyone have a plan or list for making this? Thanks for any info you can share.
1NHVStrom is offline
post #2 of 42 Unread 07-09-2019, 02:12 PM
RCinNC's Avatar
They're usually referred to as "tool tubes". If you search that term on here, you'll find a ton of threads on them and how they're built. It's pretty common among ADV motorcycle riders; I've had one on both my V-Strom and my Super Tenere.
RCinNC is online now
post #3 of 42 Unread 07-09-2019, 02:50 PM Thread Starter
1NHVStrom's Avatar
Thank you.
post #4 of 42 Unread 07-09-2019, 04:35 PM
Dragon Rider's Avatar
Plenty of people make their own, but you can also just buy them.
I guess it depends on your own personal X time = $Y money equation.
They are only $6.
https://www.agrisupply.com/manual-ca...caAoETEALw_wcB
09 DL650A
Dragon Rider is offline
post #5 of 42 Unread 07-09-2019, 04:59 PM Thread Starter
1NHVStrom's Avatar
Thanks, if I don't make my own, I will go with those. 4 bucks for the ones with no printing is amazingly cheap.
post #6 of 42 Unread 07-09-2019, 06:24 PM
RCinNC's Avatar
I dug through my old photo albums on here, and I'm attaching links to them so you can see the way I made the various incarnations of tool tubes I've used over the years.
This is the first one I made, using 4" ABS plastic pipe from Lowes. I prefer ABS because it doesn't shatter into sharp shards if it gets smashed. More photos are here: https://www.stromtrooper.com/members...tool-tube.html
This is a second version I made. This one actually went on my Super Tenere. Also made from 4" ABS pipe from the hardware store. I made this one so the door cold lock, using a modified desk drawer lock. More photos here: https://www.stromtrooper.com/members...l-su-rack.html
And this is the final one I made, which is currently on my Super Tenere. It's made from ABS sheet plastic with aluminum angle reinforcements at the edges.
post #7 of 42 Unread 07-09-2019, 09:40 PM
There are some great write ups about tool tubes. Using some plumbing pipes can cost a bit and using drain pipe can cost less, much less for the same size pipe.
Birchgroover likes this.
post #8 of 42 Unread 07-11-2019, 02:13 PM
Sq vs Round..........
RC does beautiful work.....always a pleasure looking at what he builds next!! I use the 4" diameter PVC Tube x 18" L on my Wee. I tried to build a new Tool Holder using a 5"x5" square aluminum tube from McMaster-Carr. I had it all worked out except for one area that clashed with my Happy Trails Pannier Racks....a single square bracket, but was enough for me to scrap the idea....and gave the materials away.
BTW....a 5"x5" square tube has DOUBLE the volume of cubic inches over a 4" round tube.
Just food for thought if building something.....
notacop, RCinNC, BC Rider and 1 others like this.
www.easternvstromrally.com
mark444 is offline
post #9 of 42 Unread 07-11-2019, 02:48 PM
I've got an early Shad bag mount on my salvage Wee. It has copious area on the left side. A big square design might be neat....maybe purposed as an Aux fuel tank?
I can always put lead weights on the right to offset the weight.
post #10 of 42 Unread 07-11-2019, 03:04 PM
Macdoc's Avatar
don't you have a weighty exhaust anyway?
I used the space for fuel.
richlandrick likes this.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
