Originally Posted by
Motorpsychology
View Post
I would start by reviewing the links others have provided to determine if you think this is a job you feel confident in taking on. It really is straightforward, and you shouldn't have any insurmountable problems. Next, A trip to your local hardware store, big box home improvement auto or tool section, or an auto parts store for a pair of snap ring pliers (also called circlip or retaining ring) similar to the ones that
Brockie
pictured. Amazon has them starting around $8US & up. Removal and re-installing the clips is so much easier with the right tool. You may eventually want to dive into wheel and steering stem bearings and they also commonly have this type of retainer.
Today snap-ring pliers. Tomorrow...
I see no problem with this
