Aftermarket shift lever - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 17 Old 07-06-2019, 10:30 PM Thread Starter
Joshua24:15's Avatar
Hello everyone, I ended up buying a aftermarket shift lever and realized that it wasn't the right size. Can you guys give me some suggestions and some eBay links or Amazon links to some aftermarket shift levers that would fit my 2006 DL650 ? Thanks in advance.
Joshua24:15 is offline
post #2 of 17 Old 07-06-2019, 10:57 PM
Brockie's Avatar
This should fit: https://www.vstroma.com/FldgFootShiftLever.htm
Which one did you buy?
Brockie is offline
post #3 of 17 Old 07-07-2019, 09:16 AM
Rick505's Avatar
I can vouch that one worked on my 2011 650 fine.
Rick505 is offline
post #4 of 17 Old 07-07-2019, 12:34 PM Thread Starter
I ended up buying just a offbrand shifter and should have done more research before buying , it was my bad.
post #5 of 17 Old 07-07-2019, 04:20 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
This might work as well depending on boot size.
https://www.adventuretech.biz/gear-s...extension.html
On a DL650 it works best with US size 12 and above.
richlandrick is offline
post #6 of 17 Old 07-10-2019, 05:20 AM Thread Starter
Have you guys seen any shifters under 40$? Seems there are not many others made so the producers can charge much more :sad:
post #7 of 17 Old 07-12-2019, 10:01 AM Thread Starter
I think I may just try the bolt through the damaged original shifter, wish me luck.
post #8 of 17 Old 07-12-2019, 10:15 PM
Brockie's Avatar
Use two lock nuts, and Loctite them. Round off the bolt head to save your boots, and find a gearshift rubber, or use fuel line etc. https://www.amazon.com/Motobiker-Uni...S13ZJF9XBVJKC4
Good luck.
Brockie is offline
post #9 of 17 Old 07-13-2019, 05:21 AM Thread Starter
Appreciate the advice, thanks
post #10 of 17 Old 07-13-2019, 11:21 PM
Brockie's Avatar
I just found this Youtube video.
However, I would thread the hole with a tap'n'die set, if you have one, and have the bolt head outside with a locknut either side of the shifter arm.
Gert and baroquenride like this.
Brockie is offline
