Rear Preload knob stopping point? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-03-2019, 08:29 PM Thread Starter
Hey guys,
My pre load knob doesn't seem to have a stopping point. When I rotate the knob either direction, it clicks every quarter of a turn.
Is this normal? I don't see any movement with the shock either.
Any help or info would be greatly appreciated.
GunStrom is offline
post #2 of 5 Old 07-04-2019, 02:56 AM
OCADVR's Avatar
I don't know how far it is from lock to lock but it's a long freakin' ways. I was surprised when I went to set the rear sag after I had the shock rebuilt just how much cranking I had to do to get it set. Quarter-turn increments won't be noticeable.
Jack
SoCal 92691
"I feel more like I do now than I did a while ago."
OCADVR is offline
post #3 of 5 Old 07-04-2019, 07:06 AM
Rolex's Avatar
If you watch the shock while turning the knob you should be able to see if things are moving as they should.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 5 Old 07-04-2019, 07:18 AM
Griff2's Avatar
Turning the adjuster clockwise the resistance to turning should increase as you approach maximum preload. If this is not happening you definitely have a problem. Try removing the knob to see if it has deformed on the shaft ?
Griff2 is offline
post #5 of 5 Old 07-18-2019, 04:36 PM
OnTwo's Avatar
I discovered the knob expanding at each turn feeling like its working. No change to actual preload mechanism. Threw the soft plastic
knob in the parts bin and a 14mm wrench in top box for easy access.
Whose got the cool CNC Billet aluminum replacement knob?
OnTwo is offline
